Greetings, I've got an 85 f350 6.9 it's been sitting 20yrs started a few times s year.57000
Original miles. We went to start it up s couple months ago and it's giving a horrible racket and no oil pressure on gauge. But it runs. What could have happened to I?
Depends on what you call a racket. These old trucks make a racket when they run. Is the oil light on? Do you have oil?
If no pressure, your gage or sender could be bad. Check the oil. The oil pump could have failed, screen blocked, no oil, bad or spun bearings.
I would go to one of the big stores and purchase a mechanical oil pressure gage kit and connect it where the oil pressure sender is installed in the block.
I would choose to disconnect the power to the fuel solenoid so the truck won't start, then crank it a few times to see if your oil pressure builds. If pressure builds, connect the wire to the fuel solenoid, start the engine and hope to get a fairly accurate reading of your oil pressure.
I hope this helps. Keep us posted.
My test guage is a guage with a Grease Gun extension screwed onto it. Use a guage with the fitting on the back and it's easy to screw the extension into places like the rear of an IDI block.
BTW The oil pressure port on the IDI has an "extension" screwed into the block. It's 5/8 hex. Hard to get a wrench on it, even my crow's foot / ratchet wouldn't fit. I cut an open end wrench down and smoothed off the cut end.
I past posted about jumpering the resistor on the dash cluster if you want to run the actual guage Sender instead of the warning Switch. The resistor is there to emulate the Sender being near middle of its resistance range, thereby causing the guage to see middle range all the time.
Boy I remember hitting really steep hills in my Baja Bug and seeing that oil light flicker (6psi or no oil at all). Was really scary far from home...no cell phones.. never lost an engine though....ah to be young again...
Thank you all for the replies it's going to be a while now before I'm able to get back on it but I will keep you a-breast of what I find.
Thank you
