Factory Tach
Old Nov 27, 2003 | 08:29 AM
jelzy's Avatar
jelzy
Factory Tach
I have a 85 F150XL and I am installing a factory tach. When looking through the Hayes manual it is not in detail enough for me to feel comfortable hooking it up. There is no factory harness or plug waiting for a tach. On the back of the tach are 4 terminals C, 8, G, B. Would really appreciate some help.
Thanks
Old Nov 27, 2003 | 08:36 AM
brown 4x4's Avatar
brown 4x4
You'll need the whole tach cluster to mount it in the factory position. Then it should just plug in and work, no modifications necessary.
Old Nov 27, 2003 | 08:44 AM
power_speed's Avatar
power_speed
Do What I did. Go to Helminc.com and get there new manual and throw your haynes away.
Old Nov 27, 2003 | 09:06 AM
horton-racing's Avatar
horton-racing
If Helm doesn`t have it, you can usually win them on eBay for a good price. The factory manuals are the only way to go. There are several different manuals for the year truck that you have. There will be an engine manual, a body and chassis manual, engine and emmissions diagnosis manual, a separate wiring diagrams package, specifications book and several others that I can`t remember without driving to my shop. I will be over there later today, I will look and see what I can find for you. I put a factory tach in my 86 crew cab at one time, but I don`t remember having to change the whole cluster. I could be wrong but I really don`t remember. I do remember that it just plugged in. The wiring diagrams would really help you. What year truck do you have?
Old Nov 27, 2003 | 09:08 AM
horton-racing
Now that I`ve submitted my reply, I see that it is an 85. I`ll see what I can dig up for you today.
Old Nov 27, 2003 | 11:34 AM
jelzy's Avatar
jelzy
Tach responce
So I guess what you are saying is that it is part of the cluster rear wiring, because it already mounts into the right position. Do you know if this can be purchased new or will this be a used item only
Old Nov 27, 2003 | 12:39 PM
brown 4x4's Avatar
brown 4x4
Correct. But I didn't realize the tach would even mount in a non-tach cluster. I don't know if you can still get an entire cluster new. They show up on ebay quite often, or a junkyard may have one.
It is possible to just wire it up with your existing cluster; you'll just have to study a wiring diagram.
Old Nov 27, 2003 | 02:56 PM
Big Red's Avatar
Big Red
You can still mount the factory tach and wire the terminals the same way you would for a column mounted tach. I believe that B is 12v, C goes to coil, 8 & G are grounded.
Old Nov 28, 2003 | 09:38 PM
jelzy's Avatar
jelzy
See the truck actually has all the other gauges but a tach was not included. I guess thats why it does mount into position.
Old Nov 28, 2003 | 10:46 PM
wildjon300ci's Avatar
wildjon300ci
You need the whole cluster for it to be plug and play...best $25 and 15 minutes I spent. But the tach hooks up the same way as any other tach.
Old Nov 30, 2003 | 01:03 AM
howler's Avatar
howler
I got my tach out of an XLT, as a unit, taking the whole dash cluster, and when I plugged the harness in it all worked as advertised, the wiring was in the harness already...
Old Nov 30, 2003 | 02:11 AM
Domlog's Avatar
Domlog
I just did this on my 82'. I looked on ebay and bought a cluster from an 86' Bronco. The cluster look basically identical in that they both have guages and not idiot lights. The difference between the two is that the one from my 82' (no factory tach) does not have the provision for a tach in the printed circuit. i.e. you can not just put a tach into a cluster that did not originally have a tach without wiring it seperatly. The 86' cluster has the tach already intstalled with the printed circuit connected to it. all you have to do is unhook the speedo cable and wiring harness and hook up the new cluster complete with tach. All the wiring for the tach is already on the harness, or at least it was for my truck. If your worried about it just test the harness real quick to see if your getting a tach signal.
Old Nov 30, 2003 | 11:00 AM
Big Red's Avatar
Big Red
My truck has idiot lights so unfortunately, I can't just "plug and play". I have idiot lights on my dash... ans a spare cluster with a factory tach. My plan is to install the factory tach in my dash and wire it like a column mounted tach. That should work OK.
Old Dec 4, 2003 | 07:56 PM
jelzy's Avatar
jelzy
Hey everyone thanks for all the info. I got the tach put in hooked-up and works great. Hope I can return the favor some time.
Old Dec 4, 2003 | 08:00 PM
Big Red's Avatar
Big Red
That's great! How did you install it? Just "plug and play"?
