knocking and whine from Ac Compressor
Old Jun 14, 2024 | 03:13 PM
Mitch Wood's Avatar
Mitch Wood
I have had a whine from the accessory drive for a few weeks in my '93 e250.
I figured it was the ps pump but it doesnt get louder on hills or windy roads.
today i heard a knocking noise coming from the bay so i listened and it sounds like the knocking and whine are both coming from the ac compressor.
this is happening with the ac off, and nothing changes when the ac is turned on. PO had some work done to the ac and recharged it, I think the compressor is new. it works well.
I have also had belt drive issues with the van since I bought it earlier this year, with a new belt wanting to bottom out the tensioner and ride on the edge of the tensioner pulley.
should I spend the $100 on a new ac clutch assembly and see if it solves the problem?
Mitch
Old Jun 14, 2024 | 04:18 PM
tabijan's Avatar
tabijan
How does it feel when you turn the compressor drive plate by hand?
Remove the belt. How does it feel when you spin the pulley?
Run the engine momentarily with the belt off. Same sounds?
Sixto
07 E350 5.4 198K miles
Old Jun 15, 2024 | 05:18 AM
JWA's Avatar
JWA
Before just replacing parts on mostly a whim or guess do as Tabijan suggests first. There's nothing nore foolish than not doing some degree of diagnosis first. Personally I'd look at the belt and tensioner first.
Old Jun 15, 2024 | 07:40 AM
manicmechanic007's Avatar
manicmechanic007
Agreed,
The correct size belt will put the tensioner belt wear marks about in the middle
Get that sorted out
Also, make sure the tensioner is not loose internally (the bushing) and going sideways as it moves
I think your pulley bearing on the compressor is shot (yes, remove the belt and spin all the pulleys by hand)
Good luck, have fun
ahmad_f150
2004 - 2008 F150
Sep 6, 2022 02:37 PM
josephny
Apr 20, 2022 08:16 PM
5speedjoe
Modular V8 (4.6L, 5.4L)
Feb 21, 2018 09:05 AM
rmalottwtes30
Apr 23, 2008 10:36 PM
stevegiles
2004 - 2008 F150
Aug 19, 2007 08:01 PM
