Sponsored by: Real Truck
Esof @#%#!
Old Jun 13, 2024 | 08:04 PM
Hopper123's Avatar
Hopper123
Esof @#%#!
4x4 wasn't working a couple yrs ago. Light wouldn't come one when I turned the switch. I found the plug that plugs into the transfer case was loose, pushed it in and all was good. Every once in a while I would need to crawl under and push it back on and it was fine. I needed it the other day turned the switch and nothing. Pushed in the plug and nothing. I can turn switch push and jiggle the plug on the transfer case and the light will come on at times. After the light is on it won't switch of nor switch to 4lo. Cut the truck of and the light goes off. Any suggestions?
Old Jun 14, 2024 | 12:16 AM
Antonm23's Avatar
Antonm23
My suggestion is to stop asking the truck “please , mother may I shift into 4x4 now” and start telling it by ditching the failure prone ESOF and converting it to a manual shift.
Wildhorse manufacturing (an actual US company and makes their stuff in the USA) makes a kit to do this. You’ll still have to source the shift lever and boot (either new or junkyard parts). See link below to the kit I’m talking about.
https://wildhorsemfg.com/index.php/n...onversion-kit/
Old Jun 14, 2024 | 06:40 AM
Hopper123's Avatar
Hopper123
Perfect. Thanks.
Old Jun 14, 2024 | 07:02 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Sounds like the issue is in your wiring, perhaps over the years your connectors have worn out and need to be replaced. Possibly the contacts in them have corroded to the point of being useless? Did you inspect those connections internally?
If you want to go to a manual shift that's your choice, I never had issues with the ESOF system, the only issue I had was with the vacuum hubs which were blocked off and converter to full manual.
Old Jun 14, 2024 | 07:12 AM
Hopper123's Avatar
Hopper123
I guess to replace, I would cut it off and splice it all back together?
Old Jun 14, 2024 | 10:11 AM
99powerstrokedF250
Essentially yes, you would need to get the pigtails from Ford, cut the old off, and splice them back together, whether you soldered or used crimp connectors (I like the ones with built-in heat shrink if you go that route). Replacing the entire harness would be expensive since you'd need to pull the ENTIRE body harness.
Before you go cutting and splicing, though, I would suggest checking the wiring to make sure it isn't a dead short somewhere, and that the wires are still in good shape otherwise. No point in throwing parts at it, diagnose to find the root cause.
Old Jun 18, 2024 | 09:29 AM
speakerfritz's Avatar
speakerfritz
Alternative thought
My 2010 f-450 4x4 has hub lock problems using the rotary dial.
vacuum tested the system and the hub case was leaking via unrelated bushings ….so dial control locking was no longer possible.
had to use the manual locks.
buy yes, the shift lever on the floor is always better…had one on my 2008 f-350 DRW.
Old Jul 26, 2024 | 07:53 PM
Hopper123's Avatar
Hopper123
Thanks.
if I did this I would find a mechanic to do it for me. I am leaning towards this heavily. If I went this route would the 4x4 indicator lights still display when I manually put it in 4x4h or low?
Old Jul 26, 2024 | 07:57 PM
Hopper123's Avatar
Hopper123
I'm not great at diagnosis. If I took it in to get checked by a mechanic would it be better to just take it to a ford dealership? Or is this a pretty straight forward thing for any repair shop.I get the feeling alot of repair shops around here may not know the system very well.
Old Jul 26, 2024 | 09:41 PM
Antonm23's Avatar
Antonm23
Thanks.
No, the lights on the dash will no longer indicate,,, you’d have to look down at the stick by your right leg to see what position it’s in if you can’t tell by driving.
Old Aug 27, 2024 | 11:45 AM
Hopper123's Avatar
Hopper123
I cleaned up the connections. The plug still is missing the clamp that secures it to the tranfer case but I was able to get it on and switch to 4h. After I switch to 4h I put it in neutral, foot on brake hard, flip to 4low and nothing. No click, no light nothing. I've tried rolling a little hitting the brake, waiting a minute and nothing happens. 4h is working properly though.
1. Since 4h works could it stil be the under hood relay?
2. Could the shift motor be the issue even though 4h works?
Any suggestions? Thanks.
Old Aug 27, 2024 | 03:11 PM
Pickupmanx2's Avatar
Pickupmanx2
#1 you're going to pay a lot of $$ to have someone else TS and fix the issue, unless you have a bunch laying around, I would climb under and start at the t-case motor, they do like to seize up if not used more than once a yr or so. Had a friends stop working, he rarely used it, his motor was partially toast, would go in 4h, then pop the fuse. Rplc'd the shifter motor, new fuse, good to go... my 02 F350 still has the esof, still works well "knock on da wood" I did cap the vacuum line to the front axle so I can use 2L in 2wd when wanted, then in the winter I just leave the hubs in Lock and turn the **** for 4H/4L
Old Aug 28, 2024 | 04:56 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Shift motor seems to be working. Wouldn't think its that. There might be a relay for the 4lo. Check that. I would get FORSCAN downloaded asap. That will tell you a lot
Old Aug 28, 2024 | 06:28 PM
Hopper123's Avatar
Hopper123
thanks. Gonna take it in to get it Forscaned. Also going to give the plug a detailed cleaning.
bf5113x
Apr 24, 2018 01:44 PM
Jageesey1
Dec 23, 2015 03:08 PM
bf5113x
Dec 20, 2015 09:09 AM
PaulC
Jun 22, 2005 11:38 PM
rickfitz
Oct 2, 2003 12:40 PM
