Rear wiring
Old Jun 12, 2024 | 02:16 AM
Postmortum213's Avatar
Postmortum213
Trailering
Rear wiring
So I'm about done on the wiring swap(00' to 02'), not an easy task. EVERYTHING is different. But I'm kind of stuck on a couple little things. First, on the harness that plugs in underneath mid driver door (02') it runs to the back and plugs in behind the passenger taillight. None of the harnesses I've found online have a fuel sending unit wire/plug, running board wiring provision, or rear bumper plug where the sensors are. Or where the hitch plug goes. On the 00' these ran up to the front under the hood driver side fuse box and was part of the transmission harness. I'm sure when I find out where the sending unit plug is, I'll have a better understanding, the harnesses in question is the CHASSIS HARNESS. I believe all other wiring is done. Thanks guys
Old Jun 12, 2024 | 05:29 AM
01__Excursion's Avatar
01__Excursion
So you got the rear bumper park assist harness sorted out?
Old Jun 12, 2024 | 06:52 AM
Postmortum213
Trailering
I'm actually back to that point again finally. It turns out when I converted the truck to diesel, that 2000 7.3 harness had some corrosion in the main wire harness. I been chasing electrical gremlins for weeks, so decided to switch the whole harness out for a known good one from a local totaled 2002 7.3. Long story short, found out the hard way EVERYTHING is different. So now I'm back to the rear wiring trying to get the final touches together. The Ex I got my harness from did not have the harness that plugs in and runs back to the lights. So now I'm trying to source the rear harness part for a different year. (2002 7.3) I ordered a wiring manual but it won't get here for a week
56fordguy
Apr 13, 2024 07:38 AM
Tbert
Apr 28, 2022 02:49 PM
snickers104
Dec 4, 2016 08:52 AM
Uni Moe
May 29, 2015 06:52 PM
VRMTHNT
Mar 27, 2011 07:32 PM
