wiring
Instead of making it up wire by wire, many would suggest getting an original style harness set from Chuck's Trucks LLC. He is best dealt with by phone. He has such a great inventory of serviceable otherwise unavailable components form our trucks.
Another pointer is that some of the bullet connectors Ford liked to use all over in this era are of a somewhat obtuse size as opposed to the more common .157 and .197 found today. These are roughly a .180 size connector (probably .177 in practice).
The following series from Napa work in this instance:
14-16 awg Male 724304
14-16 awg Female 724114
18-22 awg Male 724103
18-22 awg Female 724112
You can also try the original Ford part number B-14486 for male reproductions. However, it usually isn't clear if the vendor will supply crimp on or solder on versions. Some vendors have reportedly intermingled stock which is disappointing. The female/female is B-14487.
that is some good information, took me several trips to napa to get what worked
