2005 6.0 pcm issue
Old Jun 11, 2024 | 06:05 AM
BThutch75's Avatar
BThutch75
4wd Low
2005 6.0 pcm issue
I am working on my son’s truck and was told that the guy he got it from had a one in it from a 03 and that’s why things where not working right . So I order one already flashed to his vin and when it came in it was different . The one that came in had 3 spots for plugs but one of the plug in spots had no pins in it . The one that was in the truck has pins in all 3 spots . Here are some pictures any idea what is going on .
Truck wiring harness
New pcm
03 pcm
Old Jun 11, 2024 | 09:48 AM
Brotherbillstruck's Avatar
Brotherbillstruck
https://app.box.com/s/38db5e11b44694...752689&irgwc=1
Hopefully this link works. I am not positive, but one of the plugs is for the auto transmission. Did you get a pcm for a manual trans truck?
Old Jun 11, 2024 | 11:02 AM
BThutch75's Avatar
BThutch75
4wd Low
Pcm
I ordered one for an automatic transmission
Old Jun 11, 2024 | 12:47 PM
bismic's Avatar
bismic
You need (with auto transmission) all 3 with "pins". That one won't work.
The one you should get for an '05 is 6U7Z-12A650-FGCRM, but it will probably be hard to find.
Have you contacted FlagShip One?
EDIT - deleted the part from FordPartsGiant. The PCM was shown to be unavailable.
EDIT AGAIN ............... FS1 shows what you ordered is clearly for a Manual Transmission:
SKU: 10662
Condition: Refurbished
Year: 2005
Make: Ford
Model: F-Series Truck
Additional Model Info: F250; F350; F-250;F-350
Engine Size: 6.0L
Engine Type: Diesel
Transmission: Manual
Module Type: FD-F36M (PCM-122)
Part Number: 5C3A-12A650-BUE
Other Part Number: 5C3Z-12A650-BUE
Hardware Code: DPU-431, DPU-431T, DPU-441 & DPU-441T
Catch Code: UAV4
Hollander Interchange: 590-07772
https://www.fs1inc.com/oem-engine-co...-bue-uav4.html
Old Jun 11, 2024 | 01:50 PM
BThutch75's Avatar
BThutch75
4wd Low
Pcm
That is who I bought the new one from I gave them the vin number and that is what they said I needed
Old Jun 11, 2024 | 02:03 PM
bismic's Avatar
bismic
Send it back. It was a mistake made on their part. Call them and explain that you need all three connectors functional.
EDIT - one for the '06 should work for your '05:
https://www.fs1inc.com/oem-engine-co...6-0l-ttp1.html
Old Jun 12, 2024 | 11:54 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
05-07 PCMs are interchange, it's just a matter of what's on the PCM matching the truck configuration and FICM.
During the reflash process, the VIN is required on the 2003 and 2004 trucks it doesn't ask for the vin. Instead it has to be put in as part of As-built data.
Old Jul 5, 2024 | 06:11 PM
BThutch75's Avatar
BThutch75
4wd Low
Still trying to figure this out
This is the computer that was in the truck when I bought it . With talking with flagship and Ford they are telling me this one will only work in an 03 . And flagship is telling me that the one they sent me matches what my vin is aging I need . So I am trying to figure this out I need my truck back in the road
Old Jul 5, 2024 | 07:55 PM
Toreador_Diesel
What catchword is on the PCM?
Old Jul 5, 2024 | 08:36 PM
BThutch75's Avatar
BThutch75
4wd Low
Not sure what a catchword is but this is the numbers in the bottom of the pcm
Old Jul 5, 2024 | 09:17 PM
Toreador_Diesel
That's for a 2003-2004 truck. Doesn't matter if they flash it with a 2005-2007 pcm flash it won't work.
Old Jul 5, 2024 | 09:20 PM
bismic's Avatar
bismic
I think that we are repeating ourselves ...........
Old Jul 5, 2024 | 09:40 PM
BThutch75's Avatar
BThutch75
4wd Low
So what pcm do I need
Old Jul 6, 2024 | 04:06 AM
bismic's Avatar
bismic
Seems like you may have a VIN mismatch w/ the engine (or Flagship 1 is mistaken/wrong). That happens when engines are swapped out, You may need to get the engine serial number, but it is difficult at best! The engine serial number is located on the left rear corner of the crankcase.
Tell us where your ICP sensor is located.
https://alliantpower.com/sites/defau...APTB_02-06.pdf
https://goecm.com/products/2005-07-f...c3a-12a650-bve
Old Jul 6, 2024 | 04:56 AM
Toreador_Diesel
If you need a 2005 pcm for an automatic transmission, you need a pcm with one of these catchwords:
-YCR4
-ZZR7
-ZXZ4
-CYH0
-ZHB0
