Code 542, front fuel tank stopped working
Old Jun 8, 2024 | 10:14 PM
brdyer92's Avatar
brdyer92
4wd Low
The other day when I was leaving work my truck wouldn't start on the front tank. I switched to the rear tank and it fired right up, however shutting down when I switched to the front. I pulled code 542, and I had my friend bang on the front tank with a mallet which got it to run after a few taps. Does this confirm that my front fuel pump is indeed bad, or could it be something else? I'd prefer to find out before I just start throwing parts at it.
Old Jun 9, 2024 | 08:10 AM
jas88's Avatar
jas88
Your pump is most likely bad, it's a very common thing. You can check for bad connection at the pump, but most likely it is bad.
Old Jun 9, 2024 | 08:30 AM
1Butcher's Avatar
1Butcher
Fuel pumps tend to stop working t because the electric motor brushes wear out. Having two pumps changes things up a bit, but I have found pumps start to fail when they get around 150k miles. I usually replace mine around that time, in my shop, vs on the side of the road.
Jshaw3641
Jul 9, 2021 11:24 AM
Yetti
17
Jan 11, 2018 03:45 PM
57fomoco
Sep 1, 2009 07:53 PM
REELNAUTI4U
General Diesel Discussion
Oct 24, 2007 02:28 AM
icabod
Dec 4, 2004 08:33 PM
