e4od gearbox level
Old Jun 7, 2024 | 03:19 PM
Nonofordf150's Avatar
Nonofordf150
e4od gearbox level
Good morning
I'm trying to figure out how to upgrade my e4od gearbox. (Manual Ford).
I can't find anything on it, except that the cold level should be between the two circles and the hot level in the hatched area but no exact temperature, so no correct measurement.
THANK YOU
Old Jun 7, 2024 | 04:42 PM
'89F2urd's Avatar
'89F2urd
Originally Posted by Nonofordf150
Good morning
THANK YOU
Kinda vague post. What's the manual ford mean?
Are you trying to change the fluid?
Old Jun 7, 2024 | 05:35 PM
Nonofordf150
no, I would just like to check the level to see if everything is ok.
Surely someone has a Ford workshop manual that explains how to do this.
Old Jun 7, 2024 | 05:38 PM
85e150's Avatar
85e150
Drive it 5 miles. That's warm enough.
Old Jun 7, 2024 | 05:44 PM
Nonofordf150
OK thanks.
I wanted to have an exact temperature.
Old Jun 7, 2024 | 07:30 PM
'89F2urd's Avatar
'89F2urd
OK thanks.
Probably a good time to change the fluid
Old Jun 7, 2024 | 09:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
OK thanks.
150°F will be fine to check the fluid level.
Old Jun 8, 2024 | 01:46 AM
Nonofordf150
the fluid has already been replaced recently.
thank you for the temperature, I will look at my level at 150°f, so when cold I should be between the bottom 2 holes?
Old Jun 8, 2024 | 05:54 AM
Hsgill6821's Avatar
Hsgill6821
If leaks oil then it's got oil
Anyways anywhere between the lines and usually considered good and make sure you use mercon
Old Jun 8, 2024 | 08:20 AM
Mark Kovalsky
There is no spec for where it should be cold.
Old Jun 8, 2024 | 10:01 AM
1Butcher's Avatar
1Butcher
Not even close. Those that have a transmission temp gauge will attest to that. The E4OD takes a lot of oil. I think, I would have to drive at least 30 minutes to get to 150F. Outside temps and coolers matter so there is no way to say for certain without a gauge of some sort. A quick IR temp gun would be very simple to see what the pan temp is.
Old Jun 8, 2024 | 10:07 AM
1Butcher's Avatar
1Butcher
Old Jun 8, 2024 | 04:23 PM
Nonofordf150
yes, I only use Mercon.
It works, I'm going to check at 150° f with my infrared gun.
Old Jun 8, 2024 | 08:35 PM
Mark Kovalsky
Where do you get MERCON? It hasn't been made since 2006. It was replaced by MERCON V.
Old Jun 9, 2024 | 02:13 AM
Nonofordf150
on Autodoc sites, Valvoline brand racing lubricants.
