Engine noise cont...
Posted a while back about a peculiar engine noise coming from my 1975 Ford F250 360.
To recap the engine was making an odd knocking sound which does not seem to be a bearing, lifter or exhaust gasket leak.
Oil pressure is good, and the valve train feels tight.
One thing I did notice was some of the valve push rods are very slightly bent, very slightly.
The motor was gone through, (perhaps in auto shop?) and I am thinking that maybe the push rods were not returned to the engine in the same position as they came out.
After an exhaustive visual search around and up in the engine I have still not found the source of the noise.
I am now considering replacing the push rods because some are bent and because perhaps slight play on multiple rods could be making this noise, maybe.
So now I need advice as to how to proceed. I understand rods come in different lengths, and I also have an impression that removing and replacing the rocker train needs to be done in a careful manner or damage can result. Any advice would be appreciated.
Thank you!
Getting the pushrods in the wrong order wouldn't cause any noise. other than changing the wear pattern it wouldn't do anything, I never worry about it.
If it can roll a pushrod on glass and get a tick it needs replaced, if you can see a bend it's bent bad. and yes that could cause a ticking sound.
To do it correctly you need to check the preload with the cam on the base circle. this is normally done with a length checker and a custom length is ordered to get it right if needed.. if you want to shortcut it you could bring a piston to TDC compression stroke and check the preload on that cylinder. you should feel some resistance when you twist the pushrod, and you should be able to push it down and collapse it farther. this won't mean your preload is fine, it just means it should work. if you want to do it right we could go into that .
Changing the pushrods is a simple task . just back the bolts of a half turn at a time until they are loose then carefully pull the rocker shaft off keeping everything together. replace the pushrods and put the rocker shaft back on tightening the bolts 1/2 turn at a time then torque it down. you're done.
Sorry for the late reply,
When I was checking the pushrods I spun them unloaded in place they twisted easily but some rotated with a slight ellipsis so I assumed they were bent.
In my original post I uploaded a video with sound to demonstrate the noise, some of the responses led to me dropping the pan to look for metal shavings, found none.
How many variations of pushrod legnth are there for a stock 360 that has been rebuilt at least once, if that is a reasonable question.
Thanks!
Last edited by manni59; Jun 11, 2024 at 08:17 AM. Reason: this reply was to '440 sixpack'
There is a standard length pushrod that should work for most engines. but decking the block , shaving the heads, improper stem height or a cam with a different base circle height can all change the preload on the lifter. wear on components can also. checking the length with a checker is the proper way to see what length you need, then have a custom set made that length. it's a common practice.
If you want to keep it simple just bring a piston TDC on compression and twist the rods, if you don't feel some resistance then it's too loose, if it has any slop you have to do something. you need some preload, but you can't have too much. that's why a checker is really best.
If your video posted I don't see it.
I was going to buy two Howards Cams pushrod checkers and install them on the intake and exhaust valves in the compression position, set the length on both so there is a slight drag when twisted in position, then pull and measure. Is this good practice?
Hard to tell from your video, there are so many things it could be. what you say about louder on acceleration is indicative of an exhaust leak. on deceleration do you ever hear muffled popping?
But from the speed of the noise, it seems too fast to be a rod or lifter.
I have not read all the posts BUT has anyone mentioned removing all the belts to see how it sounds.
Almost sounds like an alternator bearing????
I removed all of the belts at one time and ran the engine and the noise remained.
Many have said that it may be an exhaust leak, I can see no carbon buildup around any of the ports and it does not seem to be coming from that area.
i did have to replace the RT bank exhaust gasket when I acquired the truck. it was blown out next to the heat stove for the thermo choke lines.
the noise was loud enough it covered this one I am dealing with now.
the manifold did not look damaged, nor did the head surface it was attached to.
i looked all over for cracks, recently and did not see any.
the sound has the same rhythm as a lifter noise, so if it was a leak I would doubt it would be the doughnut.
now that i think, one thing i have not done is to check around the manifolds with a fuel hose in my ear for gas escaping.
i will try that.
so with the push rods, if i do not need to check all of them for proper length, should I just check the exhaust?
I understand referencing the rods on the ends of the heads are a good sample for length, if that makes sense.
A cracked manifold will give you a tick and it doesn't always appear obvious. might even be where you can't see it. generally its worse on acceleration and often gets better after warming up.
Sometimes the best thing to do is just run it on an older engine. the problem will make itself obvious, and if it doesn't then it's not a problem.
