Sponsored by: Auxito
Need help identifying missing engine hoses & vacuum
Old Jun 6, 2024 | 06:31 PM
seijirou's Avatar
seijirou
1999 with a 5.4.
Some hoses and/or tubes have been scavenged from the engine and I'm having a hard time figuring out what they are. On the driver's side there's a port that goes into the air intake just before the throttle body, and a hose near the back that looks like it goes to the IAC. I think perhaps these connect together? Should there be some kind of tube or nipple that connects on the intake side?
On the passenger side the PCV valve is missing, and there's a tube that looks like a hose should connect coming around from behind the engine ending near the heater hoses. Also I'm the same area coming from the I take after the throttle body is another nipple pointing at the battery. 2 more hoses connect on either side of it. I'm not sure if this is vacuum related to the PCV, or perhaps coolant?
Finally back on the driver's side there's a vacuum line coming off a solenoid just above the brake booster. The vacuum line is broken from melting but I can't see where it would connect.
Hopefully the pictures help
Old Jun 7, 2024 | 07:14 AM
seijirou's Avatar
seijirou
I believe I've finally found the missing parts. The tube for the IAC is commonly called an "air bypass hose" but usually just described as "tube assembly" in parts catalogues. F75Z9H308ED
The stuff on the passenger side is definitely PCV and apparently some configurations use a heated PCV which is where the 3rd connection is coming from just after the throttle body. XL3Z6C324EA
Still unsure where the other vacuum line connects, mostly just want to find it because it may be a vacuum leak.
Quitcrying
Mar 3, 2024 09:11 AM
scottyd9
Jun 9, 2022 04:40 PM
Rick Zepeda
May 3, 2020 01:01 AM
wildstang
1983 - 2012 Ranger & B-Series
Sep 14, 2019 09:43 AM
Superblue400
Jan 9, 2019 12:16 AM
