Code P0402 just popped up
Old Jun 4, 2024 | 11:27 AM
Kemicalburns's Avatar
Kemicalburns
Good day, Truck has 172k miles. Reading up on this code it could be a dirty MAF and Air Filter. I bought the truck with 99k miles and I have not replaced the airfilter during this time so i am leaning towards this for good measure.
I will also look into pulling the EGR sensor and cleaning it. would it be wise to replace the DPFE sensor as well while I am at it?
Thanks for your time.
Old Jun 4, 2024 | 12:59 PM
bismic's Avatar
bismic
P0402:
Excessive EGR flow. This code, along with a P0404 indicates a stuck EGR valve. Could be a bad EGR valve, but also could be due to an aftermarket air filter. Could also be a dirty or fouled MAF sensor. Also possible, maybe even likely, to be related to intake leaks. The PCM uses MAF as a primary input for turbocharger and exhaust pressure control to calculate air flow for the EGR monitor.
Old Jun 4, 2024 | 02:44 PM
Kemicalburns
still running all stock under the hood except for the bluespring upgrade
Old Jun 4, 2024 | 02:48 PM
bismic's Avatar
bismic
What is a DPFE sensor? Do you possibly mean an EBP sensor? It is a 6.0L - right? 2007?
Old Jun 4, 2024 | 08:49 PM
Kemicalburns
Ya its on 07,,, i fat fingered that.
I cleared the code and will see if it returns
Stephen Mountford
Mar 12, 2020 09:34 PM
br54niner
1997 - 2003 F150
Oct 4, 2014 10:39 PM
mblack49
May 9, 2011 10:14 PM
johnkirk
Jun 6, 2010 09:36 AM
SadButTrue
Apr 30, 2000 11:38 AM
