Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C600 Vin Decode?
Old Jun 4, 2024 | 09:47 AM
kbatterman's Avatar
kbatterman
1st Gear
C600 Vin Decode?
VIN: C61DVK91419
I am trying to determine the year of this Tilt Cab C600? Can't find a year series for K91419. Any info or guidance would be great. THANKS!
Old Jun 4, 2024 | 01:23 PM
85e150's Avatar
85e150
Welcome to FTE!
C61 = C600 gas
D = 330 2V HD FT gas V8
V = Kentucky Truck Plant
K91419 = 1971 numerical series, January 1971 production
175 = 175 inch wheelbase
No color code. This truck is a special order and color could have been part of that.
C612 = C600 gas, 23,000 lbs GVWR
118
11 = Medium Gray Metallic Vinyl, OR Lt. Gray Vinyl
8 = Regular cab without sleeping compartment.
M = Clark model 285V five speed direct transmission
544
54 = Rockwell model H-170 single speed rear axle, at least 16,000 to 18,500 lbs capacity, 6.83 ratio (There should be a tag on the axle with ratio and capacity info)
4 = Ford 7,000 lb capacity front axle with power steering
23000 = 23,000 lbs GVWR
164 3800 = 164 certified net HP @ 3800 RPM
740337
74 = Seattle District Sales Office
0337 = Special Order Number
The truck specification sheet you posted is hard to read and I can't see an axle capacity on it.
What are your plans for the truck?
Check you wheels. The widowmaker wheel was still out there but we'd need clear closeup pics of the front and rear to determine that.
C-series is tough to fiddle with because nothing is reproduced.
Dougollie
May 27, 2024 06:42 PM
hoyt1995
Large Truck
Mar 25, 2024 03:52 PM
usmcpat
Large Truck
20
Mar 26, 2022 10:38 AM
J_Remy
Jun 29, 2021 03:12 PM
cayceenglar
May 22, 2021 10:24 PM
