OIL WEIGHT
Old Jun 11, 2024 | 08:05 AM
  #31
'89F2urd's Avatar
'89F2urd
Originally Posted by bismic
Another thing that would be cool to see Mark is an oil analysis at your next oil change.
I agree that would be cool, but, if it comes back with less than desirable results.....may be better not knowing lol
Old Jun 11, 2024 | 08:11 AM
  #32
wpg_250's Avatar
wpg_250
Also these 0 and 5w40 synthetic oils flow much faster/easier into all the tight nooks and passageways compared to 15w40 oils so after 10,000+ cold starts I'd imagine the thinner oil would be doing a better job of preventing engine wear, but just my thought process is all and good thing we have reliable oil analysis available to all of us
Old Jun 11, 2024 | 11:47 AM
  #33
mmenzies's Avatar
mmenzies
Can’t say that i have ever tracked mileage with 5W and 15W that carefully
Mark
Old Jun 11, 2024 | 11:56 AM
  #34
mmenzies's Avatar
mmenzies
Thanks Mark. Could you confirm your injector life/replacement history? What caused you to change out your injectors? Also, how many miles on average between oil changes - ie OCI?
Injector life is an additional "key factor" to success, (although clearly the 460k miles is the primary achievement - and a great one).
One extra variable in the mix is the fact that the CK oils have replaced CI and CJ oils. Then you have the whole Ford approval thing to think about ........ Not much long term data comparing CK and CJ oils in a 6.0L (HEUI), so many questions can still be asked!
The intent was for the CK oils to be MORE shear stable than the previous formulations, but there are still a lot of unknowns IMO. This expected shear stability should actually improve the performance of the 5W40 oil year round, but who knows specifically with a 6.0L. I have watched for good data on this, but haven't found any - not as many 6.0L enthusiasts these days. I only have a couple of runs (5k miles each) on the new CK oil, and my oil analyses results have still been as good as the previous oil.
I am at about the same vehicle weight and driving style as you. One exception is that a lot of my miles have been with a performance tune (Gearhead SRL+). Even tuned, I have always run VERY GOOD ECT and EOT. Because of that, I have little doubt that had you closely tracked the oil temperature numbers, the 5W40 would have been shown to have essentially the same oil temperature numbers as 15W40 ...... since both are 40 weight oils.
So - sounds like you should do well with the same oil change habits that you have had in the past, but my oil change data (again - mostly on CJ oils, but several with CK oil) shows that you should also have absolutely no problems w/ a 5W40 year round. Ford warned us in the early days about the lower ambient temperature issues (injector stiction) that would exist w/ 15W40. Again, maybe some of that has changed with the CK oils, but I would still not use 15W40 oil when temperatures consistently dropped below freezing because of the injectors.
Can’t say 100 percent would have to check my file at home, (Its getting to be a pretty big file) but pretty sure that I have only changed injectors once at around 190K miles. I changed the full set when I did Head Gaskets and studs oil cooler egr etc.
I do have a light tune on the truck, a PHP 40 i believe, but as I say I dont drive her with a heavy foot.
Mark
Old Jun 11, 2024 | 01:06 PM
  #35
TooManyToys.'s Avatar
TooManyToys.
Was that a preventative or failure-repair situation?
Old Jun 11, 2024 | 01:38 PM
  #36
bismic's Avatar
bismic
I found this post from you when you were at 310k miles and looking at injectors. Wasn't sure if you replaced them at 310k or not.
Originally Posted by mmenzies
What's the consensus on mass replacement. Just do the bad ones or go ahead and do all the others on the same side while you are in there. All 8 were replaced at 194K Miles and I am now at 310K They were ford remans from Tousley
Mark
Old Jun 11, 2024 | 08:09 PM
  #37
mmenzies's Avatar
mmenzies
As I say I would have to check my file which I don’t have access to right now. Maybe it was around 310K that I did the head gasket and studs (yes failure) and maybe replaced or looked at replacing injectors at that time. It will take me a couple of weeks to confirm since I am still away from home
Old Jul 4, 2024 | 12:38 PM
  #38
mmenzies's Avatar
mmenzies
Finally home. Looked in my file and I replaced all 8 injectors at 194K and then replaced them all again at 308K. I think that I when I did them at 308K they may not have been bad but I was doing head gaskets and studs and an oil cooler so I simply went ahead and replaced while we were in there. Currently at 466K and I did have a contribution code on 6 but have not lately rechecked that code and all seems to be running smoothly.
One of the more consistent issues that I have had is replacing wheel hub bearings and auto locking hubs.Cant tell you how many times i have replaced them. I do have oversized tires which is probably the root cause. Has anyone come up with a reliable auto lock hub options. I have MOTORCRAFT 1C3Z 3B396CB installed and they fail to release to free wheel with shafts turning all the way back to transfer case which probably cuts my MPG enough to do something about it. While asking does any one have a good snap ring plier model for removing and replacing the round wire internal snap ring in the auto lock hub.
Thanks in advance for the good advice that comes from this forum.
Old Jul 5, 2024 | 01:16 PM
  #39
Rellick's Avatar
Rellick
I haven't been here in quite a while, but I came looking for any updates on oil (with newer specs since I last looked). Subscribing for info on auto locking hub input.
fordflaresides
23
Jul 26, 2004 11:27 AM
Mike W
Oil & Lubrication
May 13, 2004 01:19 PM
steve81
Mar 15, 2004 07:57 PM
dinosaurfan
Oil & Lubrication
Nov 28, 2001 02:55 PM
7855F100
Oil & Lubrication
Sep 5, 2001 10:15 AM
