HEI +
Old Jun 3, 2024 | 01:02 PM
jfruser's Avatar
jfruser
HEI +
Truck: 1980 F-150 300cid I-6, 3sp manual
Howdy:
Boy is dropping a junk yard I-6 300cid into his F-150 while he does a rebuild of the original engine. He's had a chance to look at the "new to him" motor and it definitely has fewer miles and better compression. I am springing for a re-gasketing kit and EFI headers. I was wondering if this was a good opportunity to junk the computer & distro and go HEI + chinesium 1bbl Carter clone carburetor?
Anything else we ought to address on the "new to him" junk yard I-6? Freeze plugs? Belts?
Old Jun 3, 2024 | 05:14 PM
JimsRebel's Avatar
JimsRebel
I would use the newer style one piece oil pan gasket.
Info in the 300 engine forum.
https://www.ford-trucks.com/forums/1...l#post18257136
Old Jun 3, 2024 | 05:43 PM
Franklin2's Avatar
Franklin2
Howdy:
1980 300 six doesn't have a computer system on it. The substitute engine he found, if it's around 1984 or later, then it will be setup for a computer system. You can swap the distributor and carb off the old 1980 engine onto the newer engine and that would work. Or you can buy the HEI and china carb. But you only need to do this if the later engine has a TFI distributor, the 1980 engine should be ok as is.
Old Jun 3, 2024 | 06:10 PM
FuzzFace2's Avatar
FuzzFace2
I am with Dave on use the dist. and intake / carb off the 80 motor and save the money.
The DSII IGN system is just as good as the HEI and I have seen a DSII run 11 sec. in the 1/4 mile and 10 sec on spray.
That is good enough for me.
Dave ----
Old Jun 4, 2024 | 08:03 AM
Bronco638's Avatar
Bronco638
I bought a 4.9 out of a '79 F-150. In addition to what you mentioned, I'm also going to replace the oil pump when I swap oil pans ('79 is different from '80). If you're going with the one-piece oil pan gasket and will have the pan off, you might as well put a new oil pump in there. You don't need anything fancy just a stock replacement pump. Seems like cheap insurance.
Old Jun 4, 2024 | 05:17 PM
jfruser's Avatar
jfruser
All:
OK, by "computer" I meant Duraspark II system. I had a senior moment recalling its proper name. So DSII is just as good/reliable as the HEI unit? OK, will remember that.
New style oil pan gasket will require flattening out / grinding downoil pan rim, right? IIRC, it has raised bits around the pan bolts.
He's rebuilt the 1bbl Carter carb once already. Not sure its current condition.
"While We're In There" List
Gasket Kit (with newer style one piece oil pan gasket)
EFI Cast Iron Manifolds/Shorty Headers
Oil pump
Freeze Plugs
Belts
Vacuum hoses
Old Jun 4, 2024 | 05:33 PM
FuzzFace2's Avatar
FuzzFace2
All:
Oil pump
Freeze Plugs
Belts
Vacuum hoses
I will also say if you need a full exh system being you will need a Y pipe get everything for a 94 F150, less cat if you dont need one for smog.
You may need 2 mid pipes because of no cat to fill the gap.
Dave ----
Old Jun 4, 2024 | 05:49 PM
jfruser's Avatar
jfruser
Dave ----
Oh, yes, my son has exhaust system ideas. He's a welder now and he helps out buddies with their exhaust systems. That Chevy HHR you hear at 6am with the hilarious side pipes? Thank my son for that mod on his buddy's HHR. They had the extra pipe, they had the know-how, and they had no adult supervision. Don;t be too harsh, he's just out of high school.
Anyways, gathering a parts list on Rock Auto, I was reminded of the oil pump pickup & screen.
Oil pump, pickup, screen
Freeze Plugs
Belts
Vacuum hoses
Clutch, as original still in it.
Exhaust piping
Spark plugs
Old Jun 4, 2024 | 06:54 PM
FuzzFace2's Avatar
FuzzFace2
Well it sounds like he has the exh system under control
Dave ----
Old Jun 5, 2024 | 08:41 AM
Olds64's Avatar
Olds64
Definitely use the Duraspark II distributor. While HEI is a good ignition system, the modules currently available from most parts stores are trash.
I converted my classic Oldsmobile from points to HEI and I keep a spare HEI module in the glove box in case the one in the distributor craps out. I've had it happen multiple times. Especially if you want to buy a Chinesium cheapie.
I know, I know... trucks here not Oldsmobiles. Just sayin'.
Old Jun 13, 2024 | 11:44 AM
Hawkbox's Avatar
Hawkbox
This has inspired me to leave my distributor alone. I kept seeing things about HEI being a great option but I haven't had issues with my DS2 setup in my 82 and if the replacements are junk definitely not in my interest to mess with it.
Old Jun 13, 2024 | 03:09 PM
Franklin2's Avatar
Franklin2
You are correct, if you already have a DSII setup and working, leave it alone. If you have nothing, as when converting from TFI, the HEI is a great easy option to get the engine going again.
Old Jun 14, 2024 | 11:36 AM
FuzzFace2's Avatar
FuzzFace2
X2 what he siad.
Dave ----
Old Jun 14, 2024 | 11:50 AM
Hawkbox's Avatar
Hawkbox
Good to know. I should really finish soldering the coil wires back together and bolt it down one of these days. Electrical tape is good stuff but it could be better.
Old Jun 16, 2024 | 10:28 AM
jfruser's Avatar
jfruser
How are the parts store DSII modules? Relative to the unreliable parts store HEI distributors?
