Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700
Old Jun 5, 2024 | 05:15 AM
Lee Rum's Avatar
Lee Rum
Trailering
F700
Many thanks for that. Could you see if there are still any 4:88 ratio Wheel and pinion still available at the moment?
Old Jun 5, 2024 | 05:16 AM
Lee Rum's Avatar
Lee Rum
Trailering
F700
Also the calculation you did for the 4.88 ratio did you include the overdrive gear I have in your equation thanks LEE
Old Jun 7, 2024 | 06:12 PM
85e150's Avatar
85e150
Calculations included the OD gear at .78.
The 4.88 was in a two speed axle, a model 16244. I do not know what interchange there is between models. But I doubt the two speed innards would fit in your carrier, and it's a question as to whether the entire two speed center section would fit in your housing.
Found this one, 4.56:
https://wellertruck.com/inventory/pa...56-17121-18121
Parts:
https://www.globaldifferentialsupply...1-differential
Ahhh! Post 4 answers the question--the 17221 slides right in where the 17121 fits. Read it carefully about spline etc.
Some for sale here. Again, you'll need to confirm the ratios and spline counts:
https://truckpartsinventory.com/part...ingle-for-sale
Old Jul 16, 2024 | 11:41 AM
Lee Rum's Avatar
Lee Rum
Trailering
F700
Hello, I wonder whether you could be of assistance again please I have located a new gear wheel and pinion 4.88 to one ratio. It’s for a17121 diff but I have asked them if there’s any way of doublechecking this will fit my diff because of the cost of shipping it over to the UK. I don’t want to get the wrong part. They have now asked me for the gear wheel numbers on the existing 7.17 ratio, differential is there any way of finding these numbers without physically taking the diff out of the axle casing? Many thanks, LEE.
Old Jul 16, 2024 | 11:46 AM
85e150's Avatar
85e150
Pretty sure it's got to come apart to confirm numbers on a gear set.
Maybe another member will chime in.....
Lee Rum
May 31, 2024 08:49 AM
big ole ford
Large Truck
54
Feb 17, 2024 11:07 AM
Budkole
Feb 10, 2022 09:48 PM
LongRider
Large Truck
20
Dec 9, 2017 11:06 PM
PrinceValium
6.7L Power Stroke Diesel
182
Dec 8, 2017 03:42 PM
