Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1980 F-700 Detroit Diesel ???
Old 10-12-2017, 10:57 PM
LongRider's Avatar
LongRider
LongRider is offline
For the last several weeks, I have been driving a 1980 F-700 grain truck; single rear axle, air brakes, 5-speed and 2-speed axle.
The hood hinges and opens like a pickup truck = most inconvenient.
There is a bit of quandary about the engine in this truck; it is DEFINITELY a V-8 TWO-STROKE Detroit; we are all agreed on that.
Everything about the engine and engine bay appear to be O.E.M.; if it has been swapped in, whoever did it covered their tracks very well.
However, the only reference I can find to a V-8 Detroit in these trucks is the Detroit Diesel 8.2L "Fuel Pincher" V8, which is a 4-stroke.
The engine in this truck is definitely two-stroke.
I would think 318/8v71, but it does not appear massive enough for that.
I think this truck originated in Canada; were Detroit engines other than the Detroit Diesel 8.2L available in Canadian trucks ?
Could it be a 8V-53 ?
Thanks for reading.
Old 10-13-2017, 06:54 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Someone here might know about heavier trucks, but this forum is really more about the light trucks (~1 ton and smaller). You might want to try the Large Truck forum.
Old 10-13-2017, 08:03 AM
LongRider's Avatar
LongRider
Thanks!; before posting, I actually looked through the index for a large truck category and did not see one; maybe I need glasses.
Maybe a nice moderator could move this to the proper place; thanks.
Old 10-13-2017, 11:10 AM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
I’m guessing it would be a 6-71 Detroit.
Old 10-13-2017, 11:51 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1980: The 4th digit of the VIN is the engine code:
Old 10-13-2017, 12:00 PM
LongRider's Avatar
LongRider
That would be a good guess were it an inline six; it is a V-8.
Old 10-13-2017, 12:07 PM
LongRider's Avatar
LongRider
Thanks !
If I am reading that correctly, then it is possible that it could be a 8V71 as I first suspected; the next time I am near it I will investigate the VIN; it may be a few days as we finished that phase of things a couple days ago.
Old 10-13-2017, 03:07 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Thumbs up
...then it is possible that it could be a 8V71 as I first suspected...
Yes, a DETROIT V8 2-Cycle YAMAHA. They are sometimes hard to identify as they are usually covered in oil...
Old 10-13-2017, 06:42 PM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is offline
Wow, it would be very tough to get an 8V-71 in an F-700 without it looking like a total hack job and having half of it in the cab.
An 8V-71 is very large, has a blower sitting on top, and the valve covers are usually held on with two big hand nuts on either side.
An 8V-53 is unlikely. It would be a better fit than a 8V-71, but the 8V-53 is a very rare engine and was really only used in construction equipment.
A 6V-53 (V-6) would fit, and was used in a lot of trucks back in the 60's and 70's, Fords included.
You are sure it's a 2-stroke?
Got a picture?
Old 10-13-2017, 07:03 PM
LongRider's Avatar
LongRider
Got a picture?
It sure looks, sounds and drives like a two-stroke.
It is definitely a Detroit.
It is definitely a V-8
Size wise, it is comparable to a 3208 CAT
At idle, it sounds like it is turning half wide open; with the least bit of throttle, it is screaming like it is going to fly apart.
To be as old as it is, it is clean as a whistle; it barely gets rid of any oil; and it uses about half the fuel some of the other diesel trucks use doing the same work.
I filled it the other day and it only held 7 gallons; two old gas-burners that had done the same work held 39 and 47 gallons.
I will try to remember to take some pictures the next time I am around it.
One thing for certain, if we are wrong and it does turn out to be a four-stroke, it sure is trying to act and sound like a two-stroke.
Old 10-13-2017, 09:00 PM
Louisville Joe
Old 10-13-2017, 11:22 PM
LongRider's Avatar
LongRider
Old 10-18-2017, 08:58 PM
roKWiz's Avatar
roKWiz
roKWiz is online now
8V71 in a F series would be tight and heavy 1000kg ( ton) , are you sure its not a 6V53. 318 cu.
sorry, forgot about the V8 8.2 fuel pincher diesel in the above post.
Old 10-18-2017, 10:07 PM
1979 Ford's Avatar
1979 Ford
When did the 8.2 fuel pincher start showing up in trucks?
The 8.2 I drove was an 82 or 83 with an 89 cab. It was a GMC that caught fire and been rebuilt. It was a single axle dump truck that may hauled 2 1/2 yards. It wasn't a decent 10 ton tandem dump truck.
Old 10-20-2017, 03:05 PM
roKWiz's Avatar
roKWiz
In Fords, I thought 79-80 ??
Quick Reply: 1980 F-700 Detroit Diesel ???
