Rear Disc With E brake
Old Apr 19, 2018 | 06:55 PM
86F250 460's Avatar
86F250 460
Looking for just a set of calipers for my 86 f 250 with e brake cable. Guy I bought it off of converted it to rear disc but as far as I can tell there no e brake cable hookup and being he swapped to manual id like to be able to use the e brake. I know LMC sells the whole conversion kit but Id like to just get some calipers if possible if anyone knows of a company or somewhere to get em, Thanks in advance.
Old Apr 19, 2018 | 08:13 PM
Franklin2's Avatar
Franklin2
If you get different calipers, they probably won't fit your brackets. You are in a difficult situation. The calipers they used to use in the kits are from a Cadillac that had the parking brake made into them, and they are now getting hard to find. And some people did not like their performance. That is why I have never swapped from drums. And I agree, a e-brake is mandatory for me having a manual transmission, not to mention I need it to pass inspections also.
Old Apr 19, 2018 | 09:14 PM
86F250 460's Avatar
86F250 460
Kinda figured it was a stretch to find something compatible with what I have. Probably will end up having to get the kit from LMC just kinda pricey around $800 i believe
Old Apr 20, 2018 | 11:15 AM
Pappawheely's Avatar
Pappawheely
I did a conversion years ago using the Eldorado brake calipers and front rotors. The parking brake is a worm gear design that is hit or miss when it comes to working. Wish there was anything available with a parking brake but I have never found one. The ford internal hat design seems to be the only option but not sure if anything fits a full floater.
Old Apr 20, 2018 | 11:41 AM
pw700z's Avatar
pw700z
maybe there's some alternative less than $800?
https://www.speedwaymotors.com/Pinio...ake,44784.html
Old Apr 20, 2018 | 01:09 PM
Franklin2's Avatar
Franklin2
If you have fab skills, you might could make that work. I am sure the pattern on that will probably not fit the larger f250/350 pinion, but maybe all it would require is a little re-drilling. Wilwood also makes a small parking brake caliper that is manually operated. You would have to make another bracket to mount it, and let it squeeze the rear disc you are already using. So in other words the rear disc on each side would have two calipers and two brackets, the original hydraulic caliper you have converted to, and another mechanical one for the parking brake.
Old Apr 20, 2018 | 01:14 PM
Franklin2's Avatar
Franklin2
I just looked for the LMC kit and only found one for a f150/Bronco with the 5 lug 9 inch rearend for $799. If that is the kit your looking at it's not going to fit your f250. Maybe I missed the correct kit?
Old Apr 20, 2018 | 01:50 PM
pw700z's Avatar
pw700z
Going back to drums would be fairly cheap and easy, too? (I have no idea, just wondering)
Old Apr 20, 2018 | 02:50 PM
James Wagoner's Avatar
James Wagoner
Besides going back to drums, other option is driveline brake at the transfercase (if 4wd) or rear axel like suggested but matching your rear end. Either one of those will be a custom job to some extent.
Old May 1, 2018 | 08:43 PM
86F250 460's Avatar
86F250 460
I never really payed attention to the conversion kit but i noticed now it says only F100-150 and bronco which is a bummer. Where can you find the willwood e brake kits?
Old May 2, 2018 | 01:18 PM
Franklin2's Avatar
Franklin2
Here's just the caliper. I do not know if they make a "kit". Probably not. More than likely you have to make your own bracket for it.
Old May 3, 2018 | 04:38 PM
SVTDriver97's Avatar
SVTDriver97
I'm planning on doing a disc brake conversion this summer, and plan to go with lugnut4x4.com's kit. Seems I can get more product for less money than what TSM is offering. More than likely, it sounds like you have calipers from a chevy.
https://lugnut4x4.com/product/sterli...onversion-kit/
https://www.tsmmfg.net/2670.html
Here's the article written up by fourwheeler:
http://www.fourwheeler.com/how-to/tr...0-disc-brakes/
Old May 3, 2018 | 05:45 PM
Franklin2's Avatar
Franklin2
Sorry, I forgot to leave the link. Here it is. Wilwood Disc Brakes - MC4 Mechanical Calipers - Test
Old May 3, 2018 | 06:46 PM
86F250 460's Avatar
86F250 460
Well I got a hold of the guy I bought the truck from he says It has a hydraulic e brake. I have yet to try it but says there is a spring loaded **** under the dash that when you push the brake pedal you push the **** in the release pedal then **** and it holds. Personally never heard of this but ill give it a shot sometime here soon and let everyone know.
Old May 3, 2018 | 06:57 PM
Franklin2's Avatar
Franklin2
That is sort of like a line lock that the drag racers use. They work well, but they are technically not a "emergency brake" and here in Virginia it will not pass inspection as a e-brake. If you do not have inspections, and have a manual transmission, I would consider what you have better than nothing, I think you need something with a manual transmission. Turning the engine off each time you get out of the truck so it will not roll is a no-go for me.
If he has it hooked to the front brakes also, it can be an advantage when loading a trailer. Sometimes when you are loading a trailer, the trailer lifts the rear wheels of the truck off the ground and unless you are in 4x4, the whole shooting match can start rolling down the hill.
