LOL, I know, but I've had plenty of diesels, and this is my 3rd 6.7, but then again not a 2011, this one seems way less snappy, and pings way more than usual,something's not right, can't put my finger on it.
Clean your map sensor, you'll need a 7 mm socket and careful hands. Gently tap to remove built up carbon in the sensor itself, clean with carb cleaner, clean the mounting hole, and reinstall. See if that makes a difference
We just had this on a gasser I thought the timing chain jumped, replaced MAP sensor and it went away, I’m gonna try it !
Thank You, cured the problem , hope this helps
others !
