1978 - 1996 Big Bronco
pinging
Old Aug 12, 2006 | 11:29 PM
twisted's Avatar
twisted
pinging
i noticed my truck is pinging.is this from low octane gas,crappy gas or something else ?
Old Aug 13, 2006 | 12:42 AM
greystreak92's Avatar
greystreak92
5.8 or 5.0? Can't honestly remember which engine you have.
Old Aug 13, 2006 | 05:09 AM
Griffkay's Avatar
Griffkay
i have a 5.8 and i get that sometimes. i just stick in 2 bottels of fuel injection cleaner and it goes away
Old Aug 13, 2006 | 08:06 PM
chrono4's Avatar
chrono4
pingin can come from too low of octane gas, off timing, running hot, and some other things. Is it a all the time thing, or just under load?
Old Aug 13, 2006 | 09:37 PM
tom2131968's Avatar
tom2131968
Mine does the same thing. At the recommended 10 degrees of advance, it pings under load and can be quite a bear to start when hot. I retarded the timing about 3-4 degrees and all seems better. It has always been hard to time because it doesn't idle as smooth as it should but it's coming up on being 20 years old so I guess it's to be expected.
Old Aug 13, 2006 | 11:29 PM
twisted's Avatar
twisted
its a 5.8 96 xlt. sorry.
Old Aug 13, 2006 | 11:32 PM
twisted's Avatar
twisted
its not an all the time thing. mostly under loads,uphill etc. i put in a higher grade octane gas (89,was running 87) and it still did it a bit.
Old Aug 14, 2006 | 09:18 AM
HUCKSTER-USA's Avatar
HUCKSTER-USA
yea i noticed my 79 6.6 doin this lately also, only when pulling a hill on the highway, thought it was the fuel so i put some go-fast init and still does it a lil and noticed it runnin a lil hot, topped it off with some antifreeze (alil low), still does it abit so im goin to change the oil and check the timing. very irritating and embarrasing especially comn frm a tight motor
Old Aug 14, 2006 | 12:40 PM
helirich's Avatar
helirich
I might add that one time I thought my truck was pinging under load and it turned out to be the rear u-joint. It only made the sound during excelleration. I'm rather embarressed I couldnt tell the differnce. But I would rather be embarissed than chaseing the wrong thing.
Old Aug 14, 2006 | 03:43 PM
poffutt's Avatar
poffutt
Another thing that can cause ping is carbon build-up in your heads. This carbin will get red hot and cause premuture detination on the compression stroke. You may need to do a seafoam clean out. If you do this you will need to change your spark plugs after it is over. for information on this subject just put in seafoam in the search box. This procedure some people believe in strongly and others will say it can ruin your engine. I had it done at a automotive shop and it worked great.
Old Aug 14, 2006 | 08:43 PM
chrono4's Avatar
chrono4
the reason carbon causes ping, is it makes the compresion ratio higher. seafoam usually helps alot, but its known to have clogged cats before, and you ussually need a new o2 sensor afterwards.
Old Aug 15, 2006 | 01:19 AM
greystreak92
Rats, ok... the 5.8 has no knock sensor so you could possibly be dealing with any of the suggestions the folks have already mentioned. You can take the base timing a degree or two further BTDC. It sometimes helps with pinging and mileage. But only do this AFTER a thorough tune up.
Old Aug 15, 2006 | 02:56 PM
twisted's Avatar
twisted
i just did a tune up at the begining of summer. new wires ,plugs and cap and rotor.
a degree or two further..is this advancing ?
Old Aug 15, 2006 | 05:32 PM
tom2131968's Avatar
tom2131968
No, he means that you should retard the timing a couple degrees. Instead of 10 Degrees BTDC, you would set it at 8 degrees.
Old Aug 16, 2006 | 12:30 PM
twisted's Avatar
twisted
ah. thanks. sorry.
