Ac question
Old May 28, 2024 | 09:00 AM
fordman67's Avatar
fordman67
Ac question
I'm looking towards the AC side of my 76 f150 resurrection. I had planned on a sanden compressor retrofit with my oe ac system. Now I'm reconsidering this and looking around at replacement york compressors. My system worked but lost its freon in a few days last time I filled it. I'm figuring the front seal was leaking as my culprit. I don't think I'll like the look under hood of the sanden on this application also as the tensioner bracket will be kind of orphaned out in the middle of nowhere.
What's the consensus on this. I'm NOT interested in an aftermarket system for this rig.
Old May 28, 2024 | 09:14 AM
tbear853's Avatar
tbear853
I replaced the seal in my '77s York as it too leaked too, was really pretty easy to do on a bench in a cool shop.
Clutch is removed with a simple 5/8-11 bolt as I recall.
There are several videos on line. That carbon ring is fragile, my first seal kit it was broke on arrival.
I was gonna put it back in the truck and flush the system and recharge .... but then it needed hoses too, and the condenser broke at a fitting as I was trying to remove a hose, and now it's like a really good fresh air vent & heat system. I boxed my York in case I ever change my mind. I might be able to mend the condenser, it too is in the basement now.
I guess I just found myself in a pool of frustration.
Old May 28, 2024 | 09:34 AM
5851a's Avatar
5851a
I have done a York also and installed new bearings. They do tend to vibrate more than others and belt slap can be a problem on FE engines. I don't care for the look of Sandens on a Ford but they are sure smooth running. Someone mfg. a low mount that hides it under the alternator. The name escapes me now though.
Old May 29, 2024 | 11:01 AM
5851a's Avatar
5851a
Bracketry is all done! - 332-428 Ford FE Engine Forum
Old May 30, 2024 | 08:43 PM
fordman67's Avatar
fordman67
I appreciate it fellas but I'm not changing front dress on this. It'll be fine just back stock I think.
bluefeather300
Jun 2, 2022 02:27 PM
Ljblue
Feb 8, 2022 02:22 PM
Reb2973
1997 - 2003 F150
Sep 25, 2007 05:05 PM
Traxxis
1983 - 2012 Ranger & B-Series
Apr 9, 2004 03:27 PM
Chris_ce
Jul 6, 2003 08:44 AM
