1964 F100 Vin Engine code
Old May 26, 2024 | 05:31 PM
smadaw's Avatar
smadaw
3rd Gear
I just picked up a 1964 (I think) F100 for a friend. I have figured out most of the Vin / warranty tag info but want to be sure on the year and I haven't found what engine size, code A. It's a straight 6.
Here is the tag.
F10AR750399
WB 115, Color M, Model F100, Body 281, Trans C, Axle 09, Max GVW 5000, 129hp @4000, DSO 75
Thanks for any info!
Old May 27, 2024 | 10:06 AM
BarnieTrk's Avatar
BarnieTrk
SMADAW, WELCOME TO FTE !
At first I would have guessed an 'A' engine code in a 1964 F-Series Ford truck would indicate it to be a 223 straight 6 ( I6 ); but, the HP and RPM don't match up. A typical 223 was rated at 114HP @ 3600 RPM. Now a 240" I6 was rated 129HP @ 4000 RPM.....but I'm fairly certain 240s were not installed in 1964..they started in 1965.
Which side of the engine is the carburetor on ?
BarnieTrk
Old May 27, 2024 | 11:45 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Everything keys off of the last 6 digits of the VIN which gives the model year. Without the correct year everything you try to decode could be off.
F10 = F100-4x2
A = 240 6 cylinder
R = San Jose assembly plant
750399 = September 1965 build month - 1966 model year
115 = wheelbase in inches
M = Wimbledon White
F100 = F100 4x2 5000 lbs. gross vehicle weight rating
281 - 2 = Medium blue crush vinyl and medium blue match stick pattern vinyl - 81 = 81A Standard Cab
C = Ford 3-speed light duty manual transmission
09 = Ford 9" 3.70:1 (3,300 lbs rating) non-limited slip
5000 = Gross Vehicle Weight Rating
75 = Phoenix, AZ district sales office
Old May 27, 2024 | 07:02 PM
smadaw's Avatar
smadaw
3rd Gear
Thanks BarnieTrk!
Carb is on the right / pass side.
Looks like TA455OH answered all my questions. Thanks!
Old May 28, 2024 | 08:38 PM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk
Why would I ask this question?
Because its a quick way to tell the two engines apart.
The 223 has its intake/exhaust manifolds on the L side (and the carb) and the 240 has its manifolds (& the carb) on the R side of the engine.
BarnieTrk
Old May 28, 2024 | 09:33 PM
smadaw's Avatar
smadaw
3rd Gear
BarnieTry,
Awesome info! I appreciate it! So definitely a 240.
Thanks Again!
1964V8
Aug 12, 2019 04:49 PM
Gary Zaffarano
Feb 27, 2017 07:10 PM
zombiefied 247
Oct 8, 2014 04:42 PM
rwpurves
Mar 22, 2011 07:37 AM
Keith K
Dec 6, 2004 09:04 PM
