2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2024 HO Fumoto Valve
Old 05-24-2024, 10:26 AM
dag4566's Avatar
dag4566
dag4566 is offline
4wd Low
Off their website
"n some cases, this model has a plastic drain plug. We don't currently have a solution for the plastic plugs. If this is not your case, please choose a valve listed below. In addition, this Ford model uses two differently sized drain plugs. One is M14-1.5, while the other is 12mm-1.75, we suggest getting your drain bolt measured."
Any clue which one I need for a 2024 F350 SRW with the HO?
https://www.fumotousa.com/cars-picku...-f-350-6-7l-v8
Old 05-24-2024, 10:37 AM
4wd6.7L's Avatar
4wd6.7L
4wd6.7L is online now
Received 2,134 Likes on 1,603 Posts
Originally Posted by dag4566
Off their website
Fumoto is tripping, they have included, and not corrected that confusing wording for way to long. The only 6.7l pan that had a plastic drain plug was way back, something like 2011 or 12. Also, the 6.7l in the pickups only use 1 size drain plug, M14-1.5. The other size they mention is used on the gas engine pans.
I'm sure it has been brought to their attention many times but they never make the correction to their site.
Old 05-24-2024, 11:01 AM
WXboy's Avatar
WXboy
WXboy is offline
I love my Fumoto valve, and I've also used them on most vehicles I've had in the past. Wouldn't do without one. Having said that, I will mention that the design of the lower oil pan on this 6.7 engine and the location of the drain hole prevents all the oil from draining. For that reason, what I do now is I park my truck in a spot in my driveway where the nose of the truck is uphill, then I drain the oil. I'll put 12 quarts back in when I'm done, move the truck to level ground, and check the dipstick to dial it in.
It's still much easier than making a mess with the threaded drain plug.
Old 05-24-2024, 01:17 PM
redford's Avatar
redford
redford is offline
Received 1,632 Likes on 956 Posts
It’s funny. I was out in SD last week. Stopped in Rapid City at the dealership to get the oil changed. The guy who changed my oil was talking to me and complaining bitterly about the plastic plugs on the newer trucks.
Old 05-24-2024, 01:23 PM
4wd6.7L's Avatar
4wd6.7L
He wouldn't have been talking about Super Duty's though because they still (as of MY24) do not use a plastic oil drain plug.
Old 05-24-2024, 02:20 PM
redford's Avatar
redford
redford is offline
He specified the 6.7L Power Stroke. Since mine is a 2019, I haven’t seen the newer trucks.
Old 05-24-2024, 02:29 PM
4wd6.7L's Avatar
4wd6.7L
He was mistaken then.
Old 05-24-2024, 06:17 PM
sbechtold's Avatar
sbechtold
sbechtold is offline
I used this on my 24 F350 Limited. https://a.co/d/5GLIicl
Old 05-24-2024, 08:32 PM
dag4566's Avatar
dag4566
dag4566 is offline
4wd Low
Thank you! Ordered.
Buckeye71
2017+ Super Duty
35
11-20-2021 09:21 AM
F TOO FITTY
2017+ Super Duty
04-09-2018 09:17 AM
powerstroke1869
02-14-2007 06:14 AM
stevenn1
1999 to 2016 Super Duty
30
12-14-2006 06:07 PM
Quick Reply: 2024 HO Fumoto Valve
