1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
1999 F250 V10 6.8L 4x4 Battery drain issues
Old 05-24-2024, 04:29 AM
Mamabear8e1p's Avatar
Mamabear8e1p
Mamabear8e1p is offline
5th Gear
I have a 1999 F250 V10 6.8 l four by four and I can't seem to figure out what is causing the massive drain to my battery. So with a jump it starts right up , but once I disconnect the battery cables it rapidly dies(battery meter quickly goes from middle to dead) so something is killing my battery. I've replaced the solenoid, battery terminals too, but I've got a massive aftermarket stereo system that old owner admitted to not hooking up properly so I'm hoping it's the issue. I need advice! Single mom of 2 and I need my big red truck!!!
Old 05-24-2024, 04:53 AM
charlie g's Avatar
charlie g
charlie g is offline
welcome to this site.
i would start with disconnecting that radio fully, than do a charging system test, your should be getting 14.3 to 14.7 volts out of the alternator ,if not the next move is having a generator shop bench test the alternator , good luck
Old 05-24-2024, 05:00 AM
Mamabear8e1p
5th Gear
Radio disconnect
Hey thanks for the reply! Ok so it has a boss stereo in it and there are wires coming up and out from under the dash leading to the back of my truck back seats. My question is where do I begin with disconnecting the damn thing? Ugh hella frustrated!! Thank you in advance! I'm.going to go out to her now and get the exact model of this stereo too.
Old 05-24-2024, 07:00 PM
bajaphile's Avatar
bajaphile
bajaphile is offline
The fact that the engine dies when you pull the jumper cables off means it's most likely the alternator which has failed. Or, the wiring between alternator and battery are corroded, broken, etc.
Old 05-25-2024, 06:05 AM
charlie g's Avatar
charlie g
a bad alternator , that's my thoughts also, just having been a dealer mechanic and SM i tend to troubleshoot before throwing on costly non returnable parts ,yes cleaning connectors and grounds is at the top of the troubleshooting list with it being 25 years old there will be many in bad shape
OP' if there are any connections at the battery for that radio start by disconnecting them there
rodster150
2021+ F150
12-30-2021 10:05 AM
Johncc
Modular V10 (6.8l)
02-13-2021 05:24 AM
Estam
01-18-2017 04:32 PM
pauldfixr
1997-2006 Expedition & Navigator
11-17-2009 10:35 PM
tetsuo73
07-29-2009 07:59 AM
Quick Reply: 1999 F250 V10 6.8L 4x4 Battery drain issues
