Ford 400 Watt Inverter Waveform
Old May 23, 2024 | 01:53 PM
B-ManFX4's Avatar
B-ManFX4
Not anything groundbreaking or crazy, just thought I would share what the "waveform" looks like coming out of the factory inverter in our trucks. I know a few people who have said something, and have read a few threads here, about some electronics not liking being plugged into the truck. Since the output is a "modified sine wave" it is easy to see how it may upset some electronic items.
This is what the waveform looks like coming out of a Victron inverter:
This is the waveform in the truck:
Just thought I would share what my investigation revealed.
Old May 23, 2024 | 02:09 PM
speakerfritz's Avatar
speakerfritz
Yes
it pure sine wave
Old May 23, 2024 | 03:47 PM
Flyct's Avatar
Flyct
FTE Community Team
Almost as bad as my ECG when I'm in aFib.
Old May 23, 2024 | 04:08 PM
DSLTRK60's Avatar
DSLTRK60
Square wave not ideal for inductive loads, but most devices plugged into this will have a small transformer into a rectifier for DC applications anyways. Square wave inverters are cheaper and generally more simple and reliable. Thanks for sharing and cool handheld scope.
Old May 23, 2024 | 04:57 PM
Flyct's Avatar
Flyct
FTE Community Team
@B-ManFX4 I miss having a o-scope so I just ordered one. My first job was as an avionics bench tech
Old May 23, 2024 | 06:17 PM
ifrythings's Avatar
ifrythings
@B-ManFX4 should do that test again with a 100w-200w load on it and see how nasty it gets.
Old May 23, 2024 | 11:49 PM
andrew8406's Avatar
andrew8406
Anyone tried it on a 2kw inverter?
Old May 24, 2024 | 07:50 AM
rufushusky's Avatar
rufushusky
My DJI battery charger (100W) did not care for the factory inverter the only time I ran it, I am sure it is pretty gross.
Old May 24, 2024 | 08:29 AM
Need2Speed's Avatar
Need2Speed
I wonder if anyone has replaced the factory inverter with something better, easy or not?
Old May 24, 2024 | 11:36 AM
MrMBell_11's Avatar
MrMBell_11
When you say did not care for it, you mean it would simply not charge?
Old May 24, 2024 | 12:02 PM
BDWSD22's Avatar
BDWSD22
Thanks for the power details!
Thanks for the power details! I've noticed that some things don't like the FORD 400w inverter, like an old HP printer that I had and a small deep freezer. It's actually both ways though as often times the inverter shuts off when it doesn't like the load.
I thought that it being FORD quality is job #1 it would have been pure sine wave, lol. It's no matter, as I have a 5,500w pure sine wave inverter and four 900a deep cycle/starting batteries. I should build a device to fast idle the truck when a higher amp load is detected. That's better than a concrete block on the accelerator.
Old May 24, 2024 | 12:49 PM
rufushusky's Avatar
rufushusky
It would charge but very slowly, also nasty buzzing sound. Didn't want to risk damaging my only charger and batter 400 miles from home I unplugged it and found an outlet in one of the loader sheds.
Old May 24, 2024 | 06:31 PM
MrMBell_11's Avatar
MrMBell_11
Ah gotcha thanks.
Does anyone have a good source I can educate myself on items that may or may not like the square wave the truck produces?
Old May 24, 2024 | 08:21 PM
jstavtx's Avatar
jstavtx
Ah gotcha thanks.
look up six-step inverter, that is the technology, versus a more pure sine wave inverter
Old May 24, 2024 | 08:50 PM
Flyct's Avatar
Flyct
FTE Community Team
Gota Love Amazon. Ordered the meter yesterday and it arrived today.
went to the pro-power 120vac bed outlets on my 2024 F-450 and no load output is in the pictures below. It was a clean sine wave. This is hot to neutral.
Measured hot to ground and neutral to ground and had strange readings in the 80vac area. I’ll post those tomorrow when the sun comes back up.
