Massive oil leak whense parked after running
I took the turbo off my 2000 F250 7.3 powerstroke, 193k miles, cause I’ve been having the issue of having massive oil leaks, and there was about an inch in the valley of the block towards the back. So I took the turbo off the pedestal and found what looks to be bad O-rings? not sure if that could cause massive amount of oil loss after when it’s parked and driving. I attached a picture of the rings and turbo below.
Last edited by Y2KW57; 05-22-2024 at 11:55 PM. Reason: Removed color tag code artifacts from copying to render text and pics of post visible in dark mode
The following users liked this post:
The passenger side HPOP hose fitting on the head is a prime suspect as well. The oil will ooze out of the fitting or o-ring seal, run down to the plenum top edge, run back to the rear of the engine, down the vertical edge of the plenum and down to the drain. This throws a lot of people off, including me because the front of the valley is dry, so we look over the leak possibilities toward the front.
NTorreyyy
6.7L Power Stroke Diesel
01-28-2023 08:33 AM
