6.9 IDI hard start from fuel lines?
Old 05-22-2024, 05:47 PM
seanres's Avatar
seanres
seanres is offline
Trailering
Recently replaced injectors on my 1983 6.9 IDI, fixed the lope and runs way better but still super hard to start. Needs a lot of ether and some throttle to start, sometimes will start then die immediately still. I've got a return line kit on the way but was checking fuel lines and noticed some replaced lines from the dual tank selector to the injection pump. Could these hose fittings cause air intrusion, and if so how should I go about fitting them to eliminate any chance of air intrusion?
Passenger side
Driver's side
cut lines near selector valve
Old 05-23-2024, 09:04 AM
Larry1#'s Avatar
Larry1#
Larry1# is offline
Focus on the fuel lines that are under suction, not pressure.The source is likely to be the pickup screen inside the fuel tank, the tank switch valve, or a bad fitting or fuel line between the tank and the lift pump. First, switch tanks to rule out the fuel pickup. Then splice in a segment clear 3/8,fuel line as a window to detect bubbles. Start at the lift pump and work upstream.
Old 05-23-2024, 09:07 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,307 Likes on 2,300 Posts
simply put, everything i see there cold be causing your issues. zip ties on the line from return cap to filter head?
might as well just leave it open....
and all the hose clamps on suction line splices are not helping matters either.
solid lines without splices...and rubber suction lines are just asking for problems too. the rubber breaks down over time and starts letting air in......if not causes leaks.
Old 05-23-2024, 09:56 AM
seanres's Avatar
seanres
seanres is offline
Trailering
I'll try this asap, have the clear line already.
This was my feeling as well, got the truck with all those fittings like that. So you'd recommend switching to steel fuel lines between the tank and lift pump w/ compression fittings?
Old 05-23-2024, 12:31 PM
tjc transport
i ain't rite
yup. eliminate the possible leaks first.
and when you do the return line kit, use hose clamps on the line from #! to filter head. do not put the line from #1 to filter head back on.
bjmayberry2
20
07-25-2022 07:04 PM
bigcountry1009
04-05-2021 11:14 AM
crazy96863
08-01-2018 12:33 PM
Blue7.3
Australia Chapter
09-21-2014 07:01 PM
96ford250
16
12-13-2012 10:11 PM
Quick Reply: 6.9 IDI hard start from fuel lines?
