Sponsored by: Real Truck
Vacuum Pump Issue?
Old May 22, 2024 | 10:20 AM
richart's Avatar
richart
Trailering
Vacuum Pump Issue?
I have search the Forums, but cannot find anyone having my issue. The A/C blows ice cold every day on first start up and also when traveling at speed on highway. But once truck has warmed up and running at city traffic speeds, the blowing air goes pure hot! Not talking about just warm, I mean hot air like heater is on. I first installed a manual shut off valve in the heater hose, this had no effect. Had the A/C system purged, checked and recharged. Also had the A/C clutch gap checked.
Why does the A/C cooling return to normal every time I am back at highway speeds? Could the vacuum pump be failing after is gets hot? Does anyone know if the "blend door" has to see full vacuum to keep the heater core air flow shut off?
Old May 22, 2024 | 11:28 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
17 years of trucks, countless engine and transmission combinations.
No maintenance history
No real modification or change history
No indication of proper engine monitoring gauges
No location or environment indication, maybe somewhere in Oklahoma, however those tags are often not updated.
Details.....
Old May 22, 2024 | 12:07 PM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like an airflow issue across the condenser.
Old May 22, 2024 | 08:22 PM
richart's Avatar
richart
Trailering
Jimmy
2002 F350 Lariat, 7.3 Auto, DRW, Crew Cab, Long bed, 4:10 limit slip. 249,000 miles, owned for 14 years, BTS auto and tune, do my own maintenance
Patrick53
Jan 27, 2019 10:40 AM
DevilDocTater
Jan 4, 2012 07:01 AM
Fallguy2004
Sep 24, 2010 12:09 PM
GreginIndy
1997 - 2003 F150
Dec 16, 2005 08:02 AM
dpbrowne
Feb 23, 2005 02:11 PM
