Heater Selection Not Working?
Old Sep 20, 2010 | 10:04 PM
Fallguy2004's Avatar
Fallguy2004
Hey guys. On my 03 F350 I just replaced the motor. I wasn't able to drive the truck when I bought it so i'm not sure if the heater selection control ever worked. The fan works fine, the cold to hot **** works fine but the heater stays in the defrost selection and will not change.
The little gray hose is connected properly to the heater hose line.
The A/C has not been filled yet, does this have anything to do with the heater control selection?
Old Sep 21, 2010 | 06:19 AM
foul1's Avatar
foul1
Vacume leak or 4x4 silinoid at a auto hub. Search the forum several posts, one I started aswell.
Old Sep 21, 2010 | 07:57 AM
dchamberlain's Avatar
dchamberlain
All of the air direction doors are actuated by vacuum motors. The "default" position of the doors without vacuum is recirculated air through the defrosters.
So the most likely problem is you either have no vacuum (bad pump or no power to it), or a really big leak somewhere, or a feed hose to the HVAC is disconnected or broken.
Old Sep 21, 2010 | 08:53 PM
Fallguy2004
Thanks guys.
I checked around and found the vacuum pump in front of the heater motor in the engine bay. I first checked the plug for it and it had come loose or someone has unplugged it for a reason??
Plugged it back in and fired right up, then checked the main line that runs to the vacuum tank and the pump is working and drawing vacuum. The pump also turns off when plugging this line. I tried the heater controls and there is no change. Obviously there is a leak somewhere in the system but where?
Whats the best way to find a vacuum system leak? I tried listening with the motor off and being there isn't really all that much pressure in the vacuum system I didn't find anything. Next thing I plan to do tomorrow is try removing certain lines out of the vacuum tank, plugging them one by one and see if the pump turns off by itself. Meaning the system is aired up.
Any other ideas?
Old Sep 21, 2010 | 10:02 PM
dchamberlain
That's pretty much the only way. You've already ascertained that the pump runs, pulls a vacuum, holds it and shuts off when it should. Now you isolate all the system from the pump, adding in one piece at a time, until you add in a line or junction that allows the pump to run continuously. The last element will be the one leaking.
Old Sep 21, 2010 | 10:08 PM
Fallguy2004
As I thought. Thanks!
Old Sep 23, 2010 | 10:44 AM
TChap6liter's Avatar
TChap6liter
I had the same problem. I completely unhooked my vacuum pump from the tank and hooked it straight to my vent hose, which you can see going into the cab. The only thing I worry about now is having to lock in my hubs when I need 4x4.
Old Sep 23, 2010 | 02:02 PM
69cj's Avatar
69cj
I have also read that there is a hose splice/connector behind the glove box door that frequently gets disconnected for whatever reason.
Old Sep 24, 2010 | 12:09 PM
Fallguy2004
Good to know. Thx!
I will check that out as well..
JaxJim
Nov 12, 2016 02:48 PM
Mustangguy302
Dec 31, 2015 12:30 PM
ckirsch100
Dec 1, 2014 11:06 PM
cliffhanger_18
18
Nov 3, 2014 06:54 PM
sysman_rick
13
Oct 26, 2006 10:11 PM
