Radius Arm/Brake Trouble??
Old May 19, 2024 | 07:23 PM
travmarq's Avatar
travmarq
4wd Low
I recently replaced both of my radius arm bushings and noticed the driver's side brake start vibrating pretty bad while braking the day after replacing the bushings. Is there any chance these two events are correlated or is this pure coincidence and do I finally need to get new brake pads/rotors? Hoping I didn't screw with my alignment somehow or manage to mess something up while removing the rusted-on nut at the back of the radius arm.
Thanks for any possible suggestions!
Old May 19, 2024 | 07:55 PM
tbear853's Avatar
tbear853
If any correlation, it might be that you just feel what was already going on due to harder poly bushings .... or maybe the brakes started after you put it together.
Old May 19, 2024 | 08:42 PM
travmarq's Avatar
travmarq
4wd Low
Definitely possible, I noticed the brakes had been a little shaky prior to putting on the new bushings. They probably just amplified some of that.
Old May 20, 2024 | 02:20 PM
egchewy's Avatar
egchewy
4x4? you typically need to drop the axle a bit to get the radius arm out of the slot, this does put stress on the brake line unless you disconnected it.
maybe you pinched a brake line or a soft line is collapsed?
spud57
May 3, 2019 04:27 AM
miafcowboy
Oct 9, 2010 08:07 AM
menzfamfour
1978 - 1996 Big Bronco
Apr 26, 2008 01:52 PM
Frizlefrak
Jan 13, 2006 08:14 PM
Andy G
Dec 10, 2004 05:35 PM
