Need help with electrical issue.
Old May 19, 2024 | 02:18 PM
terry87309's Avatar
terry87309
2nd Gear
I have a 78 F100 Manual transmission. Recently purchased to fix up with my son for his first car.
The headlights low an high beams are working. Blinkers front an back ,Tail lights, break lights, backup lights, a cab light are not working.
Replaced the blinker switch, checked fuses, a the grounds at the taillights. Lost at this point any help appreciated!
Old May 20, 2024 | 09:45 AM
1TonBasecamp's Avatar
1TonBasecamp
A few things could be related, or they could all be separate issues.
Given that you just picked up this truck, and someone could’ve neglected it for years, they could easily be separate issues.
I would start at the front turn signal/running lights, or rear turn signal/running lights. Pull the lenses or housings out, and check for power with voltmeter at each of the terminals, with the headlight switch in the first position.
No sense in draining the battery needlessly while you’re puttering around, so the first position on the switch should work.
There is no headlight switch fuse, and we know the headlights are working, so you will have power to the headlight switch. Power for the brake light switch comes from the headlight switch, so check one of the wires coming into the brake switch. One should have power all the time, while the other only has power with the pedal depressed.
But you could be dealing with something as simple as burned out bulbs or bad grounds.
I think, not personally having run into this issue with my trucks, I don’t have a known common denominator.
Old May 20, 2024 | 10:51 AM
uzikaduzi's Avatar
uzikaduzi
cab lights as in the ones on the roof? those should share the firewall ground from the engine to the firewall and the main power wire goes through the A pillar up from the headlight switch unless they are aftermarket and have their own switch (common) i don't know when ford switched, but for a lot of years the lights were not fused. there was a built in circuit breaker in the switch itself.
Old May 20, 2024 | 02:51 PM
terry87309's Avatar
terry87309
2nd Gear
Thank you, I'll check these out an get back with my findings
King Ranch 02.
1997 - 2003 F150
Jan 18, 2022 08:20 PM
petedragoon
Mar 25, 2012 09:28 PM
robs01f250
22
Oct 19, 2009 09:27 AM
wagon burner
1997 - 2003 F150
15
Oct 21, 2004 09:18 AM
JJz400
Oct 6, 2003 11:15 PM
