Electric
Old May 15, 2024 | 09:24 PM
johnnyidaho's Avatar
johnnyidaho
Electric
My 59 has had some issues starting (just a click) then trying it again it will turn over
ive replaced the solenoid? Between the battery and starter but am curious if this part (which I cannot identify) is part of the problem thanks in advance
Trying to identify
Old May 15, 2024 | 11:40 PM
Fomoko1's Avatar
Fomoko1
Check all the battery connections especially the ground. Also make sure the battery is fully charged. In my opinion if it clicks the starter solenoid is good but I could be wrong.
Old May 16, 2024 | 12:47 PM
MARC's Avatar
MARC
Box on left
That is voltage regulator for a vehicle with a generator
MARC's Avatar
MARC
Small one on right
Horn relay switch
Old May 17, 2024 | 06:48 AM
FuzzFace2's Avatar
FuzzFace2
Yes check ALL BATTERY connections and dont throw out the old solenoid as that was not the issue 99%of the time.
The new solenoids are junk and dont last and even more so if you bought the cheapest, and thats what you get if you dont ask for a top of the line one.
Now I say 99% of the time.
I had the same issue on my 81 F100 with a 300 six.
All new battery cables as part of the cab off frame rebuild, run just like the factory had them.
Every so often I would get a click a few time then it would start.
I cleaned every connection again just to make sure and it was worst so I bought top of the line NAPA solenoid and never an issue again.
So yes that 1% it could be a bad solenoid but most it is a connection.
Dave ----
Old May 17, 2024 | 09:52 AM
johnnyidaho
many thanks "cab off frame rebuile, run just like the factory had them" I had moved the ground wire to the engine off the firewall, I will replace it.
Old May 29, 2024 | 09:07 PM
johnnyidaho
Found the positive lead to the battery was loose but did check all grounds as well
ow I’m driving the truck and I get intermittent loss of engine and she bucks as a result. Any thoughts?
I have pulled the distributor cap and cleaned off the six leads plus wiped the top of the rotor. Any suggestions
thanks
Old Jun 7, 2024 | 10:26 AM
FuzzFace2's Avatar
FuzzFace2
thanks
I also did a 4 year cab off frame rebuild of my 81 F100 flare side and I ran everything like the factory had and had no issues other than the old solenoid I reused.
So just driving down the road the motor shuts off like someone turned the key off or something else?
So going over the grounds you have battery to motor, motor to frame (81 dose frame then to top bolt of starter) and motor to cab (motor to firewall).
With the grounds run like that power should have a full path from / to battery.
If it just cuts out I would look at the IGN system as we know the grounds are good.
Are you still running points or a kit to replace them?
As a test I would "hot wire" the coil so the IGN is powered up all the time and see if it cuts out.
If it dose not cut out hot wired then I would say the problem is either power to the switch or from the switch to coil.
If it cuts out it would have to be from coil to dist.
Dave ----
ps when running move the wiring to the coil and dist. and see if it cuts out.
Old Jun 7, 2024 | 07:05 PM
johnnyidaho
Dave ----
thank you. I will try my best and follow your details
Old Jun 8, 2024 | 05:11 AM
joes99's Avatar
joes99
I had an issue with a 302 distributor. The internal ground wire would short as the vacuum advanced. I replaced it with a factory braided one and no more issues
Old Jun 8, 2024 | 07:32 AM
johnnyidaho
Thank you, I will check it
Old Jun 10, 2024 | 10:01 AM
FuzzFace2's Avatar
FuzzFace2
An easy test is to remove the hose to the vacuum advance and test drive.
If it dose not cut off then yes look inside the dist.
Dave ----
Old Jun 30, 2024 | 07:23 AM
johnnyidaho
Update
i renewed the cap, rotor, plugs and points
when I drive the truck the engine misses and backfires
i believe that it could be the setting on the points but could use some guidance
thanks in advance
Old Jun 30, 2024 | 07:26 PM
spurredon's Avatar
spurredon
Backfires sound more like timing or wires in the wrong order.
Old Jul 1, 2024 | 04:30 AM
johnnyidaho
Thank you, I am certain the wires are correct as I placed each one on the new cap as I removed it from the old cap
