Electric
Old Jul 7, 2024 | 01:10 PM
johnnyidaho's Avatar
johnnyidaho
Found the problem as I did not set the points correctly. Set them at .025 and no issues WRT backfire or missing.
New cap is numbered so I followed those positions when replacing the plug wires.
As always many thanks
Old Jul 7, 2024 | 01:30 PM
Beechkid's Avatar
Beechkid
FYi- take a q-tip and apply a small amount of teflon lube to the distributor shaft cam- where the cam rotates and open/closes the points..... they use to include a little tube of this but stopped amny moons ago....it does 2 things 1) helps the points open/close smoothly and 2) Most importantly it reduces/eliminates the rub block on the points from wearing so the points stay in adjustment much, much longer!
Old Jul 7, 2024 | 03:59 PM
johnnyidaho
Many thanks
BSJ49
16
Feb 26, 2024 05:27 PM
6.9_4spd
13
Sep 14, 2023 08:51 AM
TGiordano87
38
Oct 9, 2022 09:28 PM
vaellene
Jul 31, 2021 08:17 AM
Prof.Eugene
Nov 8, 2020 08:11 AM
