Lower Control Arm Bolts
Old 05-14-2024, 03:41 PM
tarzanjane's Avatar
tarzanjane
tarzanjane is offline
I have a 2010 F150, 5.4L, XLT, 4WD, Extended cab, Heavy tow Package.
During Truck Inspection I needed to replace the lower control arm. When removing the Control arm bolts to rear one wouldn't budge and I had to cut it out. So the problem is I cant find a duplicate replacement. Everything listed is are upper control arm bolts. Ford says they are called a Cam Service Kit 7L123B236AB $125.55. I told they the ones I removed were not cam bolts. Something seems nefarious based on the lack of information.
Any explanation would help. Also if I am to use cam bolts what is the new torq spec.
Thanks
Old 05-14-2024, 05:06 PM
tarzanjane's Avatar
tarzanjane
Bolt sitze
I assumed upper and lower were the same size not even close on a 2010. Why is Ford telling me they are Cam Bolts. Someone must know this. The parts salesman didn't know the answer. He didn't even know the size.
Old 05-15-2024, 04:04 AM
RLXXI's Avatar
RLXXI
RLXXI is online now
Mr. Electric
Received 1,386 Likes on 1,097 Posts
Cams replace the oem bolts that are ONLY used during assembly. The cams are required in order to perform a proper alignment as well. I've used them for decades. The first vehicles I remember them being used on was when they made a drastic change back in the 80's on GM trucks. Torque specs should be included on a read me sheet or printed on the box itself.
They sell many diffent brands of cam kits, here's one example. https://www.partsgeek.com/g3shj6q-fo...xoC6sAQAvD_BwE
And a brief video explanation.
Mustangguy302
1997-2006 Expedition & Navigator
10-20-2014 11:12 PM
frankg3079
1997 - 2003 F150
02-14-2013 08:11 AM
BURNSTOUGHFORD
11-16-2009 03:03 PM
Pablo-UA
Aerostar
04-30-2006 12:00 PM
copper_90680
Aerostar
02-08-2004 07:08 PM
Quick Reply: Lower Control Arm Bolts
