4r7ow loss of 4th gear
I have a 2007 f150 that dropped out of 4th and into neutral. I turned overdrive on and limped home with no issues except for the higher revs. I took the valve body out and found a couple pistons that were being held up by a check ball that fell apart. the overdrive servo was intact and in place and the overdrive band seems to be intact. after i refilled the transmission I took it out and had it kick out of 3rd instead and again if i turn off the overdrive it drives fine. dont want to do a rebuild if there is something else that I am missing. the fluid looked good didnt have splinters or burned smell. anyone have any useful advice for me?
The following users liked this post:
Received 1,415 Likes
on
Welcome and sorry to hear of your troubles. Help is in the 2004 - 2008 F150forum you posted in, good luck with this.
thanks I am pretty sure its either the overdrive band thats burned or that drum on the foreward clutch. I tried to downshift from 60km/hr and get very little if any engine braking does anyone know if that would indicate one or the other? I heard that if the overdrive band is broken you wont get engine braking. not much more i can do but have a mull before deciding to remove the transmission. just trying to understand exactly what could be wrong as i hate admitting defeat.
The following 2 users liked this post by Ford Motor Company:
This doesn't sound like a minor issue to me. It probably needs to come out.
You might want to try starting a new thread over in the "Clutch, Transmission, Differential, Axle & Transfer Case" forum.
Welcome aboard!
Welcome aboard!
Joe Wolf
07-24-2023 09:27 AM
paul cass
New Member Introductions
03-05-2014 03:38 PM
