I'm closing in on 30K miles and at that time I'm planning on changing my driveline fluids.
The service manual states:
- Front diff level should be "within 3mm from" fill plug opening
- Rear diff level (M275) should be "10-15mm below" fill plug opening
- Transfer case level should be "within 10mm below" fill plug opening
Besides the fact that the verbiage is unclear, any ideas on how to achieve these fluid levels? Here are the options I've considered so far:
1) Waste a bunch of time dicking around trying to fab a tiny dipstick
2) Fill by spec volume only
3) Fill to overflow, suck out a guesstimated amount (aka pinky finger test)
4) Fill to overflow, plug it and rock on
If you want to be ocd and do it like the book says, bend a piece of bailing wire into the shape of an L with the short end being 10mm. Then when you need the 3mm, clip off 7mm.
This is going to be your minimum or low level, level should be"within Xmm from" fill plug opening. On level ground, fill case till it runs out of opening, stops dripping (within reason). install plug.
