Changing fluids
Old May 13, 2024 | 03:37 PM
Hmcfly626's Avatar
Hmcfly626
Changing fluids
Ok I was watching a video on YouTube saying you should get you differential fluid and transmission changed every 30-60000 miles so I called ford and they said every 150000 miles I have a 6.7 diesel in it but 150000 seems like it's a bit long just like changing oil every 10000miles is to long for me any ideas thanks
Old May 13, 2024 | 04:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Trans & differentials every 50-75k miles IMO. 150k is a BS number Ford pulled out of their rear-ends...they just want a failure out of warranty hoping to drive more sales.
Old May 13, 2024 | 06:14 PM
Hmcfly626's Avatar
Hmcfly626
Changing fluid
thanks so much that's kind of what I had though
Old May 13, 2024 | 07:53 PM
number9xd's Avatar
number9xd
I did my engine oil, transfer case, and rear axle at around 1,500 mi. Did engine oil again at 5,000 and every 5,000 since.
I’ll do the front axle sometime this summer (truck has 23,xxxmi), and transmission at 50,000 prob.
Old May 14, 2024 | 06:24 AM
WXboy's Avatar
WXboy
I changed my trans filter at 81k miles. It took almost 9 quarts of Mercon LV to refill to correct level. At 91k miles I drained again (didn't remove the pan this time) to get more of the old fluid out and only had to put in 6 quarts to refill to correct level. So apparently the filter/pan holds almost 3 quarts of fluid that won't drain. I found that interesting.....
At this point I've got 15 quarts of fresh LV in the trans, so now I'll start doing it every 50k miles. Probably will wait and hit the next interval at 150k even to make it easier to remember.
Old May 14, 2024 | 06:33 AM
rufushusky's Avatar
rufushusky
Youtube is loaded with opinions on everything... some good, some not so good. Ford has some really long service intervals, mainly to keep the total cost of ownership stats down. IMHO I get very leery about any service life recommendation beyond the warranty period of the vehicle. Personally, I go 60k or so on diffs, x-case and trans. Mercon LV (or ULV for the 10R140) is pretty tough stuff and honestly I think it could survive but I would rather not chance it. Unless your towing constantly 30k miles seems a bit excessive but not my money.
Old May 14, 2024 | 07:29 AM
AmateurWheels's Avatar
AmateurWheels
I like to change the rear for the first time at 10k. Every 30-50k beyond that. Front dependent upon use. Xfer every 50k.
Old May 14, 2024 | 08:43 AM
hindy's Avatar
hindy
Not related to the super duty but the wife's explorer manual states transmission fluid change at 150K. It currently has about 135K on the clock. I went into Ford have the transmission fluid changed and the Ford service guy said they won't touch it if the transmission fluid has not been changed before 100k. He stated they have been experiencing transmission issues if the transmission fluid was not changed before 100k. Maybe a selling tactic to get me to buy a new vehicle, I don't know. Just wanted to give my two cents.
MAX4utah
Oct 4, 2021 05:29 PM
FUJINAMI1293
Jan 14, 2013 07:55 PM
ole_smokey_88
1997 - 2003 F150
Dec 14, 2009 05:22 PM
RocketScience
Oct 29, 2006 11:14 AM
jcandrew
May 13, 2003 11:30 PM
