Hydra Tunes
Old May 12, 2024 | 07:29 PM
fdevies21's Avatar
fdevies21
Originally Posted by Tpayne621
If there jelibuilt tunes I would contact them and ask for there opinion and see what they say. The tunes they write control tranmission parameters as well.
I did and they wouldn’t help me, had bought the chip from a diesel place in AZ. Where he gets his tunes from jelibuilt.
Old May 12, 2024 | 07:35 PM
Tpayne621's Avatar
Tpayne621
Well you can order new tunes from anybody. Jelibuilt. Sdk. Gear head. AA. Anybody can order them. You don't have to get somebody to do it for you. You just need your pcm code. Serial number off the hydra. And your mods you have done. Then email it to them and they email you the tune files and you load them on your hydra. You can buy jsut 1 or 2 tunes to start with to see if it's actually a tuning issue.
Old May 12, 2024 | 08:01 PM
Kintla's Avatar
Kintla
I just posted about a similar issue. TC lock up sucks when running a tune and I think mine is tuning related as well. Or, hoping so. It's a newer HD transmission and TC.
I just changed transmission fluid per recommendation of Mark K. Seemed to help lock up when in stock mode but if I run a tune the TC lock up is slow and herky jerky especially if into the pedal at all. RPMs jump around too. If you put yours in stock mode how is your lock up?
I was going to give Jellbuilt a shot and see if it helps.
Old May 12, 2024 | 10:07 PM
rsqfxr's Avatar
rsqfxr
had a trans issue with their tunes as well, was told they are the same tunes they run on their trucks, ended up happy with tunes from the PHP modified library
Old May 12, 2024 | 10:18 PM
kd5zll's Avatar
kd5zll
IF you choose to get new, custom tunes, i will say ive been very happy with my AA tunes the past 3 years.
Old May 12, 2024 | 10:32 PM
fdevies21's Avatar
fdevies21
in stock mode still have TC lock, my problem is when it locks up my truck bogs down. To where it won’t go as I keep pushing the pedal down. Once it unlocks it has all the power and like nothing ever happened.
Old May 13, 2024 | 02:23 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by cleatus12r
Lots of places do them. Google is your friend.....when it's not spewing a particular propaganda.
It's only a particular propaganda.
Old May 13, 2024 | 03:38 PM
L-ight's Avatar
L-ight
I also have an issue with my TC. When it locks soon after it shifts into 4th/OD making it seem like a very short shift. I have custom tunes from Jeli and they could never get it worked out. It works fine on the modified stock one.
Old May 13, 2024 | 03:42 PM
ESwift's Avatar
ESwift
CNCFAB
It is typically supposed to lock as soon as it shifts to 4th.
Old May 13, 2024 | 07:25 PM
L-ight's Avatar
L-ight
Definitely does not do that. It makes it feel as if my trans has 5 gears, not 4.
Old May 13, 2024 | 07:46 PM
ESwift's Avatar
ESwift
CNCFAB
So you aren't feeling it do the normal 1-2, 2-3, lock tc while in 3 (can feel like a shift to some people), then the 3-4 with tc locking right away?
If not, what exactly is it doing or feel like its doing?
Old May 13, 2024 | 08:44 PM
fdevies21's Avatar
fdevies21
let me know if it does
Old May 13, 2024 | 08:53 PM
  #28
L-ight's Avatar
L-ight
It does 1 to 2, 3 to TC lock then about another 6 or 7 mph it shifts to 4th.
Old May 13, 2024 | 09:04 PM
  #29
ESwift's Avatar
ESwift
CNCFAB
So it is locking 4th at the same time it shifts, or are you feeling it lock later after its already in 4th?
It should not be hard to have the tuning adjusted to delay that shift to 4th in order to avoid lugging the engine down so much.
Old May 13, 2024 | 09:10 PM
  #30
L-ight's Avatar
L-ight
It locks before 4th. I have some youtube videos of the issue during a wot run.
