Sponsored by: Auxito
2000 F150 Dash Electrical Issue Help
Old May 12, 2024 | 04:00 AM
Jbo_c's Avatar
Jbo_c
3rd Gear
Removed the dash on my 2000 F150 when I replaced the heater core. Have a couple of issues that I assume are related. I’ve taken it back apart and cleaned and reconnected wiring twice, so don’t think that’s it.
Symptoms: Auto headlights not functional(but manual works fine), cruise control not functional, speedometer remains at constant 33ish mph when truck is on regardless of speed(or even whether it’s in gear). Tach and odometer appear to be functioning properly. No problem lights/codes.
None of these are critical to me, but would be nice if they worked right. Any suggestions? As noted, seems not to be the connections behind the instrument cluster, which was, of course, my first assumption.
Thanks.
Jbo
Old May 12, 2024 | 09:07 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Sounds like the sunload sensor under that dash lid on the passenger side got disconnected somehow.
Speedometer…lost a ground to the circuit? It seems to be getting current and I doubt you swapped wires around to make the needle stick.
Cruise may have gotten disconnected in the clockspring.
Either way, tough to tell without being a fly on the wall while you were reinstalling everything.
Old May 12, 2024 | 10:13 AM
Don Ridley's Avatar
Don Ridley
The problems do not have an obvious connection (common fuse, module etc.). The cruise control uses the VSS (speed) signal from the PCM. It also uses the speed servo control module. The autolamps are controlled by the autolamp module.
Here are the wiring diagrams for a 2000 F150:
https://charm.li/Ford%20Truck/2000/F...d%20Diagnosis/
Of course, check the fuses for the two modules. Then pick a problem and see if you can find wiring or a connector you had to disturb when replacing the heater core. Ground connections are important so look at the wiring for the grounds.
Old May 12, 2024 | 01:41 PM
Jbo_c's Avatar
Jbo_c
3rd Gear
Dang. Was hoping(expecting) they would be connected somehow making an easy/obvious fix.
Jbo
Old May 12, 2024 | 04:35 PM
Don Ridley's Avatar
Don Ridley
Check Fuse #5 in the Central Junction Box. 15 amp
It powers : DRL, Speed Servo, Fctn Switch, Blend Door actuator, Digital Transmission Range sensor.
Old May 13, 2024 | 05:54 AM
manicmechanic007's Avatar
manicmechanic007
Check all the connectors near the left kick panel
Check the ones on the right side again
Under the hood, check all the connectors by the processor and verify the wires coming from the starter relay are correct
brc777
1997 - 2003 F150
Oct 28, 2019 01:33 PM
Busyb187
Mar 14, 2019 12:29 PM
Marcel61
Apr 16, 2016 08:07 PM
kennyrandolph
Sep 1, 2009 09:23 PM
