Shock busted weld
Old May 10, 2024 | 04:45 PM
Deadbuck's Avatar
Deadbuck
Shock busted weld
Picked my truck up from the tint shop and the front passenger shock bottom mount weld is broken and the shock is hanging. WTF? Is this a common issue? Easy fix?
Old May 10, 2024 | 04:59 PM
tbear853's Avatar
tbear853
I've welded eyes on shocks, but was after I cut it off to change some aspect. You have to keep the shock cool to prevent it 'splodiin' though
Never had a shock eye break off a shock though.
Old May 10, 2024 | 05:14 PM
Deadbuck's Avatar
Deadbuck
it sheared off where it mounts to the axel I guess. Not real sure. I saw it hanging this afternoon. I’ll get under the truck and investigate more tomorrow.
Old May 10, 2024 | 10:35 PM
Deadbuck's Avatar
Deadbuck
Not sure how it happened
Old May 11, 2024 | 05:52 AM
m78's Avatar
m78
I would double check the shock part number to make sure it's correct for the truck.
Old May 11, 2024 | 08:51 AM
tbear853's Avatar
tbear853
Oh, I see .... it's a F250. Shock mount tab just broke off. Easy fix with welding. Lots of years, flexing, & that front tire over on the road edge, the roughest part of the road, heavy axle and wheel and tire bounce to fight .... etc. Not unusual.
Old May 11, 2024 | 09:33 AM
Deadbuck's Avatar
Deadbuck
The driver side is mounted differently than the passenger side. Is that normal? The driver side looks like a beefier mount.
File Type: pdf
File Type: pdf
Old May 11, 2024 | 09:35 AM
Deadbuck's Avatar
Deadbuck
They are the basic Monroe shock 32286. Is it worth upgrading to a nicer shock? Ranchero, Rough Country, Etc or no noticeable difference in ride quality?
Old May 11, 2024 | 10:24 AM
tbear853's Avatar
tbear853
A nicer shock that does what shocks do ... but better ... is gonna not make life easier on that mount. It will need to be welded back, and I'd reinforce it too. That's a MONROE32286 Monro-Matic Plus,More Information for MONROE 32286 (rockauto.com)
If you lie the ride, why change it?
Old May 11, 2024 | 02:32 PM
nutter3's Avatar
nutter3
Drivers side 1979 F250 dana 44 shock mount
Passanger side 1979 F250 dana 44 shock mount. Disregard the brake hose connections, those are not stock.
Old May 12, 2024 | 11:16 AM
Deadbuck's Avatar
Deadbuck
It looks like the passenger lower shock mount is a thin piece of metal and if I get it welded back on it will be a weak point. Do they sell replacements online? Bigger beefier ones? If so I can't find them, maybe I am searching for the wrong keyword? Thanks for the help!
stylesidetruckguy
Jul 25, 2022 04:51 PM
Jonnyuma
May 17, 2022 03:05 PM
JTyler11688
Dec 3, 2009 04:14 PM
randallc
Apr 24, 2003 05:28 PM
