2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
2024 F150 Trailer Brake Controller Module
Old May 8, 2025 | 12:33 AM
  #76
MandJ's Avatar
MandJ
Still struggling to get OEM trailer brake controller to work
Thanks for the website link homerjay84! If the TRM swap works for you and I hope it does, it gives me hope we can find one for my truck. I wouldn't be surprised if their parts numbering system has errors in it.
I'm going to call it a night! Best of luck and thanks much for the advice and assistance!
Mark
Old May 8, 2025 | 06:03 PM
  #77
homerjay84's Avatar
homerjay84
4wd Low
MandJ:
Update on todays service was positive and negative.
Yes that module works and I have trailer brakes in my truck now. No as in every time I start the truck I get a Trailer Brake Module Fault each time and intermittent Trailer Wiring Fault. The tech isn't sure if its a bad TRM or not as I was an open box from a different dealer. They have ordered another but not sure when it will come available.
Hope this helps in your quest.
Old May 8, 2025 | 08:34 PM
  #78
MandJ's Avatar
MandJ
Thanks homerjay84! This is encouraging news! Do you have either a trailer hooked up or a 7-pin connector-tester plugged in, to get that message when starting the truck, or is the error message (Fault) coming up with nothing plugged in? Once the error message comes up, does it clear from the screen and everything works properly afterwards?
Although it may not be the case for you, there's another blog above from "newfrank" (you may have seen it) mentioning his (or her) 2023 F150 having had a corroded wiring issue at the 7-pin plug inside the bumper. This was causing error issues that went away upon replacement of the plug, which the dealership did after other attempts to fix the errors issue didn't work.
Old May 8, 2025 | 08:51 PM
  #79
homerjay84's Avatar
homerjay84
4wd Low
Hey this is starting up with no trailer connected. The gain changes and the tech used a voltage meter and confirmed there is voltage when the slider is activated.
I did read that post about corrosion I was going to take a look tomorrow after I wake up from nights. I'm skeptical about it how ever as my truck is less than a year still from build date. The dealer left it installed with a request from Ford engineering for help. They think the module may be a dude as it was an open box transfer from another dealer that is unsure why it was opened. I'll test it this weekend with my trailer and see how it goes.
Old May 8, 2025 | 08:58 PM
  #80
MandJ's Avatar
MandJ
Thanks again! Best of luck on getting it completely fixed, and I will keep it posted on how my situation goes.
Old May 12, 2025 | 11:07 AM
  #81
homerjay84's Avatar
homerjay84
4wd Low
MandJ
Quick update. I tested it this past weekend with an actual trailer and no dice. Did not recognize there was a trailer present. When I left the dealer they told me it was throwing a "Trailer Brake Module Fault" on the screen but try anyways. After I left it also start throwing "Trailer Wiring Fault" errors. When I called them this morning for something else I mentioned that error and they thought that was interesting. Apparently as you said someone else had to have their harness replaced at the back, my dealer rep confirmed it was a common issue on the 22's.
What was interesting is as I was driving to work this morning the truck beeped about halfway through my trip and said trailer disconnected then the brake and gain controller started acting as normal. When I would squeeze the trigger it would beep and say no trailer connected, as it should when functioning properly. They are taking it for a couple days to check it out and check wiring issues as well. They also may explore the route of bringing in another TRM of same model form a dealer out west that supposedly has 1 in stock. See how things go.
Justin
Old May 14, 2025 | 04:20 PM
  #82
MandJ's Avatar
MandJ
Hello! Sorry to be slow but I'm traveling now. Thanks for keeping me and everyone else updated on this! I'm confident there are a lot of people who can benefit from this info, as there are so many F150s out there, and many owners would like to easily install OEM trailer brake controllers. Hopefully dealership can troubleshoot this successfully, and I believe getting attention from the best tech people at Ford HQ is the key to solving these problems. Thanks again!
Old May 16, 2025 | 09:38 PM
  #83
homerjay84's Avatar
homerjay84
4wd Low
Hey MandJ
I have a success story. The final part they used are both parts in the kit RL3Z-19H332-AA, the slider and the TRM module. They removed the RL3Z-19H332-B module as I guess the AA replaced it. with a different programming configuration.
If you have a 53T spec'd truck then the dealer has to follow the instructions provided. If your truck is not a 53 spec'd truck then its a different procedure. the tech had to go in and tell the system the modules are there then flash only the TRM itself on the truck. If he tries to flash the whole truck it will try to look for a minor feature code FDDAA "brake valve" which is not present on trucks not spec'd with 53T. The flash will then fail. I wasn't able to speak to the tech himself as he had gone for lunch when I arrived to pick up my truck. He followed a procedure from Ford Tech support however.
This all being said I would think that only trucks spec'd with 53T can be setup and run with owner by using FORSCAN. Given the fact the tech needed to flash a different code into the module for my truck I would think people with vehicles only spec'd with the 7 pin and tow hitch should go to your dealer.
Hope this helps.
Old May 17, 2025 | 09:05 AM
  #84
MandJ's Avatar
MandJ
This is greatly helpful homerjay84! I will pass this info along to my Ford dealer, who will be working on my truck this Tuesday.
I believe you are helping a large portion of the F150 community, assisting Ford Tech Support to pay attention to and resolve this issue!
I'll keep you posted on my progress.
Thank you very much for posting this information!
Mark
Old May 18, 2025 | 03:10 PM
  #85
MandJ's Avatar
MandJ
Hey homerjay84,
Would it be possible for you to provide the name and phone number of the Ford Dealership that worked on your truck, in case the dealership I use wants to contact them on this, please? That way they could get quick advice on the method if they needed it. I would provide them the info you said and that might be enough, but they will want to get it done quickly and this would be a good option.
Thanks again!
Mark
Old May 25, 2025 | 07:50 PM
  #86
homerjay84's Avatar
homerjay84
4wd Low
MandJ,
Forgive the delay in reply, its been a busy week and a bit for me.
Towed with it the past weekend and system works great. I now have some other issues I'm not too happy with, one being the the fiberglass shocks installed on trucks without the max tow package. The sag is real even with my weight distribution hitch and my 5000 lb trailer.
The dealer is Airport Ford Lincoln in Hamilton ON. I have what they put on my invoice I can put that down see if that helps.
Old May 26, 2025 | 09:17 AM
  #87
MandJ's Avatar
MandJ
Still struggling to get OEM trailer brake controller to work: Finally got it working!
Great news for me, and hopefully helpful to others out there!: The local Ford dealership was able to get the OEM trailer brake controller working on my truck! I told the service manager about your success homerjay84 (thank you again!) and he put his best electronics tech on it. I wasn't able to talk to the Service Manager or the tech after they finished, but I believe they used a direct line connection to program the module and truck rather than using wifi connection, as the Service Manager said Ford tech support had suggested this. I also had handed him a printout of your recommendations for programming the module separately from the truck also, so hopefully that helped them.
This is really encouraging and I'm glad I had the time to wait for guidance from fellow F150 owners (like you homerjay84, and others above in this blog) and the dealership to resolve this problem! It took a while, but it paid off! Other F150 owners without factory trailer brake controllers: don't give up if you can afford some time to resolve the problem!
Also, this highlights the power of being able to share ideas and info in a forum like "Ford Truck Enthusiasts", so kudos to FTE!
Thank you very much homerjay84, and others above, for sharing your ideas and technical information to solve this problem!
Old Dec 17, 2025 | 06:21 PM
  #88
Jsbm70's Avatar
Jsbm70
2nd Gear
Help
Originally Posted by scottevision
Please try the following.
Plugin the original module. You can leave the new one screwed in.
Launch Forscan, go into the TRM (as built) and save all for your TRM backup. Exit Forscan.
Reconnect the new module
Launch Forscan, go into the TRM (as built) and load and write your backup of the original module to the new.
Clear and reload DTC errors
Go into the TRM and enable the brake controller option and write it.
Go into IPC and enable (trailer brake, trailer brake controller and trailer brake gains). Write it.
It should now work without the DTC errors.
I had one installed and now my battery light is on. Any help?
Old Dec 17, 2025 | 06:42 PM
  #89
homerjay84's Avatar
homerjay84
4wd Low
What year truck? Did you install it or a dealer? Was your truck equipped with a tow package or tow prep package?
Old Dec 18, 2025 | 08:54 AM
  #90
Jsbm70's Avatar
Jsbm70
2nd Gear
2024 f150 trailer break controller
It’s an xlt,5.0,long bed crew cab. 302a. I installed and took to dealer to program. For some reason the battery light came on after programming and they can’t figure out why. Ford engineering is involved now and they are asking the tech to inlay a new wire( not sure from where to where)
