GT40 Heads Conversion
Old May 9, 2024 | 09:29 PM
RMiranda's Avatar
RMiranda
Trailering
Howdy folk, doing a GT40 heads swap in my 5.0 94 f150 stock engine. Will my 5.0 intake and exhaust manifolds bolt directly to the Gt40 heads with no modifications? What do I need to swap these heads?
Old May 10, 2024 | 12:11 AM
TobyB's Avatar
TobyB
In looking at the same thing, the exhaust manifolds... are a bit of a challenge.
t
has not yet found a set of reasonable heads. Is still looking.
Old May 10, 2024 | 04:30 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes. Gasket set. Maybe use a pushrod length checker to verify nothing has changed?
Reinstall the ones that were on the truck
Old May 10, 2024 | 11:32 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Im looking at the same thing, the exhaust manifolds... are a bit of a challenge.
Only if you got GT40P heads
Old May 10, 2024 | 11:56 AM
Scndsin's Avatar
Scndsin
The head bolt holes "could be" 1/2" rather than 7/16 which might require either bushing or different head bolts.
The set I pulled of an un-molested 5.0 Explorer had both. To use on my 5.8, I had to have on set drilled to 1/2"
I would invest in a push-rod checker & mock it up to be certain of the length needed.
Old May 10, 2024 | 11:24 PM
TobyB's Avatar
TobyB
erp- yeah, that was it.
t
1994f1505.8l
Oct 15, 2014 11:49 AM
James Patrick Harris
Jun 6, 2013 05:18 AM
hizzle
Modular V8 (4.6L, 5.4L)
Apr 2, 2008 01:51 PM
john fin
Mar 10, 2008 07:11 AM
