1970 Ford 2wd Headers
Old May 9, 2024 | 06:27 PM
rrwolfjr's Avatar
rrwolfjr
Trailering
I searched lots of threads talking about headers and some briefly mentioned issues with headers and power steering with a 390. Has any one found any headers that worked with the power steering and didnt heat it gearbox up to bad, would ceramic coated ones help?
Old May 13, 2024 | 12:28 PM
mustang808's Avatar
mustang808
7th Gear
I installed Whitebox headers on my 390 and had to bash the crap out of #8 tube to clear the power steering knuckle.
Old May 13, 2024 | 12:55 PM
rwolfjr's Avatar
rwolfjr
6th Gear
Thaks for the info. Did your setup look like mine for the steering?
Old May 13, 2024 | 01:38 PM
mustang808's Avatar
mustang808
7th Gear
Mine is a 67 with Bendix power steering. The headers also hung about a half inch lower than the trans cross member and had to make a new intermediate pipe to go over that to connect to the collectors. It was a real pain in the butt and understand why they only cost $120 LOL. Of course the passenger side went in with no problems except for the cross member.
Old May 15, 2024 | 04:25 AM
Crop Duster's Avatar
Crop Duster
What you have there is a Ford Integral steering gear it isn't a Saginaw. Try calling Summit or Jegs and tell them what you have and let them recommend a set of headers that way if they don't fit you can return them. But be aware almost all aftermarket headers may require you beat on them a little somewhere. If you have 1/2-inch clearance on the PS box that's plenty especially if you use a PS cooler. Get ready to get your check book out if you want a good set of headers that are coated and will last.
Old May 18, 2024 | 06:22 PM
rrwolfjr's Avatar
rrwolfjr
Trailering
Thanks guys for all the responses, sorry it took me so long to respond have been busy working on the truck. I am trying to get all the floor pans and cab corners welded up and some rusts spots done anyways. The truck goes off to the painters in July after I test fit all the front clip parts for fit so he can then finish removing the cab and bed to get it soda blasted, then i will bring frame back and install all driver train. This is the long answer to why i am needed to get headers ordered lol. I do have a power steering cooler and since I dont have the bendix gearbox hopefully i can find some long tube header that will work. I just got a 10K order from LMC so I need to go check it in and store it, the fun never ends lol.
Old May 19, 2024 | 01:34 PM
broodlyric's Avatar
broodlyric
I fit a set of hooker super comps that I believe we're for a mustang. No problems with power steering, the starter had to come out and reinstalling took some finesse. I'm a bit worried about the heat on the starter as well. Also had to cut a small section of frame on the passenger side. So far no problems for me.
Old May 23, 2024 | 11:31 AM
deckertd's Avatar
deckertd
I used these in ceramic. '71 F-250/390/PS/PB/2WD Camper Special
https://sandersonheaders.com/product...earch_word=390
Old May 25, 2024 | 11:28 PM
RTT's Avatar
RTT
Red face
I believe these to be block hugging headers . There are 3 MAIN types of headers , block huggers , full long tube , shorties . My understanding/opinion is if you do not use full long tube , the others are not worth the price compared to the HP gains !!!
Also install at least a foot of header collector pipe ...... I also am concerned about heat by my starter !!! I have long tube and are very close to my starter
I plan to buy a fancy small high torque unit in future or try some kind of heat shield , or both......
Old May 29, 2024 | 09:28 AM
mustang808's Avatar
mustang808
7th Gear
I put in a powermaster 9106 high torque mini starter and wrapped it in a heat shield. So far I haven't had heat soak issues.
Old Jun 16, 2024 | 11:28 PM
RTT's Avatar
RTT
Red face
I think wrapping ANYTHING will cause rust because wrap will trap/hold water... ......
CJMOStang
Jan 3, 2023 10:13 AM
mwvdub
17
Mar 8, 2009 11:42 PM
galaxie64
Dec 17, 2004 11:16 PM
