Sponsored by: Real Truck
Switched (Key On) Source at Bed?
Old May 8, 2024 | 09:50 PM
castellscl's Avatar
castellscl
I can not find a switched/ Key on/accessory 12v source to save my life at the rear end of the truck. It's 2011 F250 6.7L BTW. Everyone says the 7 pin is only active with the key on. I can tell you for a fact that mine is ALWAYS hot. I left the truck overnight and came out and checked the 7-pin and it was still hot. Is something wrong with my truck, a relay stuck closed? I ask cause everyone swears the 7 pin on works with the key in the ignition. All that being said, does anyone know of any other switched/Key On(accessory) 12v sources at the rear of the truck?
Old May 17, 2024 | 12:47 PM
castellscl's Avatar
castellscl
I opened the distro box under the hood and found the relay was gone and a jumper wire installed. Anyone know if the relay is the same as the one in slot 101? (8t2t-14b192-aa) If so a cheaper source like autozone/advanced,oreillys?
ofrcboy
Oct 13, 2021 12:55 PM
GeoKar Smithorrell
2009 - 2014 F150
Feb 10, 2021 07:12 PM
Pennsyltuckian
Jun 13, 2018 10:15 PM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
RavageX
13
Apr 4, 2013 01:35 PM
