Headlight conversion help!
Old May 8, 2024 | 07:49 PM
Kdog5432's Avatar
Kdog5432
2nd Gear
I have a factory 2017 lariat ultimate Halogen truck that had an LED conversion already done when I purchased. I decided to do a face lift to a 20-22 LED front end. So I tried using the same adapter harness and it plugged in fine, light turn on (no high beams as expected) but the “c” won’t light, now I did switch the pins in the connector how I read the factory 17 LED trucks are doing but did nothing on my end. Any recommendations ? I’ve heard I have to run a wire straight to the ignition but looking for some more advice.
Old May 9, 2024 | 04:46 AM
JeepPuller's Avatar
JeepPuller
How was the led conversion done originally? When I converted my 2017 king ranch from halogen to oem led, I used the Boosted Grey goose harness which added pins to the harness inside to allow for communication to the led lights. I also used Forscan to update some settings for the C to operate properly.
Old May 9, 2024 | 04:50 AM
JeepPuller's Avatar
JeepPuller
This thread was invaluable for me
Led conversion thread
Old May 9, 2024 | 06:30 AM
Kdog5432's Avatar
Kdog5432
2nd Gear
great question, I believe it was a retro customz adapter harness, there was a small box in the truck labeled retro customz with Obd connector which I assume was for the forescan codes
thomashardyboy
Apr 19, 2024 08:45 AM
Dzlinmyblud72
Jan 2, 2022 08:10 AM
Milwaukee,WI
Dec 1, 2005 02:40 AM
Deeznuts
Jun 26, 2005 06:53 AM
weldman
Mar 26, 2002 11:44 PM
