What did this plug into?
Old May 8, 2024 | 12:20 PM
6t56's Avatar
6t56
Does anyone know what this red plug went to ? Notice those 2 fuseable links that have been twisted together for some reason?? Anyone know what those are and where I might find the rest of the wire for the shortened one?
Old May 8, 2024 | 02:51 PM
Mountain_anderson's Avatar
Mountain_anderson
your old truck may not be as old as you think it is. That's the very early version of the odb detection system. Very handy system, you can get a diagnostic computer for it still at autozone today for about $30. I just found that out recently on my bullnose as well, it works wonders
Old May 8, 2024 | 03:05 PM
FuzzFace2's Avatar
FuzzFace2
As for the fuse link going to need a little better picture of where the other ends go to.
Wonder if 1 blew and they just put the other in like that to get going?
What electrical dose not work on the truck?
Dave ----
Old May 8, 2024 | 03:16 PM
Max Capacity's Avatar
Max Capacity
This site maybe some help to you.
https://www.garysgaragemahal.com/1986-evtm.html
https://www.google.com/search?q=obd0...t=gws-wiz-serp
Old May 8, 2024 | 04:51 PM
6t56's Avatar
6t56
Not sure what works and what doesn't. When I got the truck it didn't have a starter, starter solenoid, and all the wiring is chopped and hacked.
I'm not even sure what engine it came with originally, right now it has a 300/6 in it. I'm in the process of eliminating everything except 12v to run the HEI and whatever I need hooked up from the alternator.
If that red plug is for a OBD I'll just rip all that out too. This truck could never be put back the way it was so I'm going to try to make it easy on myself to get it going again.
Old May 8, 2024 | 04:57 PM
Franklin2's Avatar
Franklin2
I don't know if I have replied to you before, but when you get the truck running good with the new distributor and new carb, go in the cab and take the computer out. It's over the transmission hump behind the dash. Unplug the big wiring connector and fish it through the firewall. Then gently tug on it, undoing anything that was connected to the computer. That plug you are wondering about will go with this wiring you are tugging on and pulling out.
riggermortis
1966 - 1977 Early Broncos
Jan 8, 2022 12:09 AM
Twonky
Sep 21, 2017 07:42 AM
jaagen
20
Jan 11, 2016 10:43 PM
jaywhy
Jun 9, 2014 08:50 PM
cabldawg
3.8 & 4.2L V6
Dec 23, 2008 07:26 PM
