Sponsored by: Auxito
96 trouble
Old May 7, 2024 | 11:06 AM
Doss 85's Avatar
Doss 85
2nd Gear
96 trouble
I have a 96 f-150 that keeps dying on me while goin down the road, but if I turn my key to off position and back on it fires right back up without having to crank it and I'm not sure where my issue is at.
Old May 7, 2024 | 01:02 PM
BareBonesXL's Avatar
BareBonesXL
Could be electronic/electrical. 96 uses the ignition control module. Maybe a dying fuel pump. Supply more info about the truck - engine, miles, how long it worked correctly for you. "96 f-150" is not much to work with.
Old May 7, 2024 | 01:29 PM
Doss 85's Avatar
Doss 85
2nd Gear
It's got 156,000 miles on it. I just replaced the module on it and also the in line fuel filter but not the pump
Old May 7, 2024 | 01:40 PM
BareBonesXL
Good luck. Tell a full story with details and somebody might havee some ideas. Bits and pieces over many posts is kind of painful. If you had said that you already replaced "the module" I might not have suggested it. Round and round. Might just be a poor electrical connection. Many possibilities.
96 f-150 with new module and fuel filter. Stalls then restarts immediately.
Old May 8, 2024 | 05:07 AM
manicmechanic007's Avatar
manicmechanic007
Check your fuel pressure
Your pump is getting another run signal when cycling the key
Ronniewhite
May 11, 2023 11:50 AM
Frozen_Joker
Nov 20, 2013 12:02 PM
Eddie
16
Mar 17, 2001 11:08 AM
