Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
How Does A Governed Engine Work ?
Old May 6, 2024 | 10:01 PM
blake in spokane's Avatar
blake in spokane
Holley carb - I got 2 vacuum lines to the distributor + a vacuum advance line - where do they really go ? And what do they do ? What do things on the side of the carb really do ? Can parameters or max rpm be adjusted ?
Old May 6, 2024 | 11:23 PM
85e150's Avatar
85e150
Since you have a non-oem carb, it's hard to tell what the things on the side of the carb do.
Can you post a picture?
There were governors that were a separate plate with butterflys below the carb.
And there were governors built into the carb, where the throttle plates could be controlled by a linkage or vacuum signal.
In both cases, a vacuum signal came from the distributor. One vacuum line went to the distributor, and at a certain rpm, a mechanism allowed vaccum to return to the carb to pull the throttle plates back.
This post has links to factory shop manuals explaining how they work and showing illustrations.
For reference, OP has some kind of carb issue on his 361:
https://www.ford-trucks.com/forums/1...l#post21214819
Old May 7, 2024 | 06:09 PM
asavage's Avatar
asavage
FTE Community Team
Originally Posted by 85e150
. . . there were governors built into the carb, where the throttle plates could be controlled by a linkage or vacuum signal.
In both cases, a vacuum signal came from the distributor. One vacuum line went to the distributor, and at a certain rpm, a mechanism allowed vacuum to return to the carb to pull the throttle plates back.
I'm glad you reminded us that OP has non-OE carb.
My '73 F600 361 2V has a Holley 2300 LIST 6548 and has the integrated vacuum diaphragm on the throttle body, opposite side (passenger side) from the accel linkage connection. A picture I happen to have handy:
A sleeve in the distributor base slides via flyweight to open/restrict vacuum to that carb diaphragm.
That said, allowing the FT to rev higher is really counterproductive, as the torque falls off fast, and they crack (pistons? rods?) if run regularly beyond the governed speed (or even at the governed speed) according to (destroked?) what I've heard. They're not built to rev.
Old May 8, 2024 | 10:00 AM
Destroked 450's Avatar
Destroked 450
Without photos and numbers from the present carburetor it would be near impossible to determine what you need to do the make the carb work properly on that engine
Ford vacuum governor uses a centrifugal weight in the distributor to control vacuum being drawn on the carburetor mounted governor diaphragm thus regulating max rpm
If the carb you have is from a IH truck I’m not sure if that governor works the same, it should but each mfg seamed to have their own idea on how to govern the their engine
On a Ford a vacuum line connects to a port in the main body above the throttle shaft, this line runs to a vacuum port in the distributor housing. Originally another hose with threaded fittings runs from a threaded port in the distributor back to a threaded port in the governor control on the right side of the carb, this completes the circuit
The centrifugal weight controls the amount of vacuum being drawn on the governor diagram which in turn moves the throttle blades thus limiting the engines max rpm
If a carb is installed that will not work with the factory governor some type of electronic rev limiter should be installed to protect the engine from over reving
Old May 8, 2024 | 11:46 AM
Louisville Joe's Avatar
Louisville Joe
The above post is right. Newer Ford medium duty trucks had a vacuum solenoid to control the governor rather than the flyweights in the distributor, but the carburetor was basically the same. It is really a mistake to replace a governor type carburetor with an aftermarket type on a FT or Super Duty truck engine, you won't get any more power out of them and run a good chance of blowing the engine up. Ford put them on for a good reason.
Old May 13, 2024 | 05:55 PM
roKWiz's Avatar
roKWiz
This might help, Gov. I know OP maybe aftermarket but please put these pages somewhere for future reference.
Old May 13, 2024 | 06:46 PM
85e150's Avatar
85e150
You current post, and a prior post as well as some others are in the Tech Section up top, posts 9 and 19:
https://www.ford-trucks.com/forums/8...-1-2020-a.html
Old May 23, 2024 | 12:19 AM
roKWiz's Avatar
roKWiz
Great, good to know. Hope it can help someone.
DieselDog409
13
Sep 8, 2023 08:55 PM
cmjacko
Aug 18, 2022 11:18 AM
AdamRF
Nov 20, 2011 01:51 PM
lavatan
Apr 21, 2011 02:06 PM
Als F-600
Mar 17, 2004 05:25 PM
