Tips for removing front Spindal on 94 f150 Danna 44 ttb
Hey everyone I’m replacing my front axle U joints on my f150 and im at the part where I need to remove the Spindal and it’s pretty rusted on there. I’ve been using a chisel and dead blow like a lot of people have recommended. I’ve thought about using an air hammer with a chisel attachment, is this a bad idea? If so any other advice?
thanks in advance
thanks in advance
I would not do that. You definitely do not want to damage anything. Keep doing what you are doing, making sure to hit the spindle in different directions. When there is a gap between the spindle and knuckle place a chisel or flat blade screwdriver in there. Keep working back and forth;up and down. Work the chisel/screwdriver farther in as the gap opens up. It will eventually separate.
The following users liked this post:
I went slide hammer and threaded puller route, it works well. But now that my truck gets regular front end service, with anti seize, I take the nuts off the spindle studs and just pull the spindle off by hand. I've used the slide hammer for other projects though, still a good tool to have on hand.
91dirtydiesel
13
02-14-2011 09:43 PM
95redbeast4x4
11-30-2010 09:11 AM
bobby d
12-04-2004 08:34 PM
