quick question on TTB dana 44
Old Feb 13, 2011 | 10:32 PM
91dirtydiesel's Avatar
91dirtydiesel
Workin on a buddies f250 and we replacing the ball joints. On the driver side knuckle we are stuck trying to remove the spindle off there. So we can get the axle shaft and u joints out of the way. We took the nuts of the studs and its frozen up. We tried hitting it and no luck. I know u guys are very creative so any ideas on how to get it off??
Old Feb 13, 2011 | 10:51 PM
Country_boy_2007's Avatar
Country_boy_2007
try a little heat, you could also try a slide hammer if you could figure some way to get a puller on it
Old Feb 13, 2011 | 11:00 PM
Jayme Duty's Avatar
Jayme Duty
When i just did mine on my 94 D50 i used a sh**y chisle and pounded it in between the spindle and dust shield very nicely and that did the trick
91dirtydiesel
Don't have heat or a slide hammer. Puller didn't work
Old Feb 13, 2011 | 11:05 PM
91dirtydiesel
We tried the chisel and had no luck. We beat it pretty good from all angles
Old Feb 13, 2011 | 11:08 PM
Jayme Duty's Avatar
Jayme Duty
next option=bigger hammer
Old Feb 13, 2011 | 11:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Take a 4x4 and put it on the front of the spindle.
Middle big hammer and smack the 4x4 5 times.
Move to the back of the spindle, repeat the above.
Some penetrant, PB Blaster, sprayed around the studs and the back of the spindle.
Repeat above.
Repeat above.
When you start to get some movement, then you can slide a chisel in the opening and smack toward the chisel.
Reverse and smack again.
Just make sure you only hit on the 4x4, a blow to the spindle will reduce it to scrap metal.
If you have a spare spindle nut, you could run it 1/2 way on the threads for extra protection.
When you are ready to reinstall, paint the back of the spindle and mating surface with Never Sieze.
Good luck.
Old Feb 13, 2011 | 11:41 PM
91dirtydiesel
The only problem with that is the axle shaft is still in the spindle. So if I where to hit the front, it would hit the shaft
Old Feb 14, 2011 | 12:16 AM
tecgod13's Avatar
tecgod13
I think Dave meant to hit near the front of the spindle, but along its length. Not the actual front. Basically hit the threaded area, but the 4x4 protects the threads.
Old Feb 14, 2011 | 12:37 AM
91dirtydiesel
Oh gotcha ha well we tried that with a rubber mallet. It didnt work. So now its got a good shower of brake cleaner so we will see tomorrow.
Old Feb 14, 2011 | 01:16 AM
polarismuddman's Avatar
polarismuddman
A rubber mallet is pretty well useless...do the 4x4 and BFH trick...usually works.
Old Feb 14, 2011 | 05:13 PM
Dave Sponaugle
Last year I had to change what I am sure was a 1997 U joint in my 97 350.
Short handle 8 pound sledge and a 4x4 that was not looking very good when the spindle finally came loose.
Hit the end of the spindle up, down, forward and backward.
Forward and backward works best if you turn the wheels left for backward, right for forward to get the best swing on the hammer without hitting the fender on the drivers side.
Reverse that for the passenger side.
Old Feb 14, 2011 | 07:12 PM
93Fodge's Avatar
93Fodge
+1
A lead hammer is VERY handy, as well. You can beat the snot out of anything with a lead hammer and not cause any damage to the threads/part, as the lead will just conform to the item being beat on.
Old Feb 14, 2011 | 09:43 PM
91dirtydiesel
We got it! The 4x4 with a sledge hammer did it haha
kruc
Sep 13, 2016 09:42 PM
pat420swed
15
Sep 18, 2015 02:38 PM
LutzBoy
Dec 6, 2014 03:56 PM
11xmiller
Aug 8, 2014 09:36 PM
cory5517
18
Sep 27, 2013 02:44 PM
